Height and position of custom shower valves
Discussion in 'Shower & Bathtub Forum & Blog' started by flighttnc, Jan 10, 2006.
  1. flighttnc
    flighttnc New Member
    Dec 29, 2005
    Hi,
    I have a custom shower that is being installed and have questions regarding the positioning of the components. The ceiling height in the bathroom is 8 feet. I am 5'7" and the tallest user is 6'1".
    I had asked to have the thermostatic temperature control valve set at approximately waist height (my waist height, about 40" from the floor), with the volume control valves (two) slightly above the thermostatic valve.
    I came home today to find the valves much higher than I expected. The thermostatic valve has been installed at my chest height (about 51" from the floor) and the volume control valves have been installed above the thermostatic valve level with my nose (about 61" from the floor.) The bathroom floor will remain at the same height.
    I also have three body sprays and a shower head that have yet to be installed and had asked to have them installed on a pressure balanced loop, positioned as follows (as per Grohe's positioning guidelines):
    Top-level: shoulder/back height
    Mid-level: waist/hip height
    Low-level: thigh/knee height
    Shower head: above the level of the tallest user
    I have the following questions:
    1) Are there set guidelines or standards for any of the above components (i.e. in inches from the floor) using the height of my bathroom (96 inches) that I can give the plumber to place the valves?
    2) Should the valves be positioned away from the outlets or does this matter?
    Any input or experience would be greatly appreciated. Thank you in advance for your help!
  2. hj
    valves
    EVERYTHING is cosmetic and aesthetic. So you can install them wherever you want to and at any height. My preference for the volume control is about 42" above the floor, in a location that is accessible as you enter the shower enclosure, with the temperature control below it.
  4. flighttnc
    Dec 29, 2005
    Thank you hj---I appreciate your help!
Similar Threads: Height position
Shower & Bathtub Forum & Blog Marble Threshold Height Above Tiles Oct 10, 2016
Shower & Bathtub Forum & Blog What height to install my niche relative to my subfloor? Jul 18, 2016
Shower & Bathtub Forum & Blog Shower Riser Height for Handheld Shower Jul 8, 2014
Shower & Bathtub Forum & Blog Shower curb height Mar 15, 2014
Shower & Bathtub Forum & Blog Raise Shower Head Height? Feb 21, 2014
