Heavy condensation on my pressure tank
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by dwassner, Sep 6, 2012.
  1. dwassner
    dwassner New Member
    Jan 31, 2012
    NEW YORK
    I have a 308ft well that was dug within the past 6 months and our pressure tank is sweating pretty bad. I understand that the cold water is bringing the temp. of the bottom area of the tank below the dew point temperature. It is a wellmate fiberglass tank that is roughly 4 ft tall. I also just installed and am bypassing a softener and assume that once in use, it will have the same issues. The pressure tank sits on a base so i cannot wrap the entire area with insulation. I would like to solve this so a mold issue does not start. Is there a jacket you can zip around the tank? Or something you could apply to the surface of the tank? thanks
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I also have a WellMate composite tank and had no problem to wrap it in insulation. I also wrapped both the iron filter and softener. I used the foil and bubblewrap insulation. You can make cuts in it to form it to the curves and then use foil duct tape or vapor barrier Tuck tape.
    I often wondered why someone doesn't come out with a wetsuit like material with a zipper.
    BTW, I only wrapped the WellMate up to the high water mark. It doesn't sweat on the top third.
  4. dwassner
    dwassner New Member
    Jan 31, 2012
    NEW YORK
    OK, I will try that. Did you wrap between the base and the tank? Was it only one layer of insulation? I didn't realize there was a high water mark...
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    I wrapped the bottom curve down to the plastic base but nothing under the base. I used 2 layers. As for the high water mark, my tank doesn't have a bladder. A bladder tank would be different. If it sweats all the way to the top then cover it to the top.
  6. bcpumpguy
    bcpumpguy New Member
    Jul 27, 2012
    Langley BC
    Funny you say that, there is a company on your side of our beautifull country that does, can't quite think of the name right now but once i get to work tommorow i'll let you know. But that is exactly what it is, wetsuit material with a zipper. They might only have it for filter tanks though.
  7. bcpumpguy
    Jul 27, 2012
    Langley BC
    excalibur water systems
    Telephone: 705.733.8900
    1.877.733.8999
    Fax: 705.733.8904
    E-mail: info@excaliburwater.com
    Address: Barrie Ontario L4N 8W8
    Canada
Similar Threads: Heavy condensation
Pumps and Tanks Well Forum & Blog. Water is life. (New)Merrill Heavy Duty Pressure Switch and Control Box Jun 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Water Cloudy After Heavy Use Jul 29, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Discoloration after heavy use? Jan 23, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Sump pump going on every minute in heavy rain (but pumping water) Sep 8, 2011
Pumps and Tanks Well Forum & Blog. Water is life. dirty well water after heavy rain Mar 9, 2011
