heating upstairs zone works, downstairs doesn't - New piping
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by philtrap, Aug 24, 2013.
  1. philtrap
    philtrap Member
    Jun 19, 2013
    Civil Engineer
    Long Island, NY
    Folks,
    I just fired up my TT-110. The upstairs zone works fine. The downstairs (the one to the left) doesn't. The pipe above the valve hardly gets hot. Even when the circulator pump is on and the the second zone is closed. The Diff Bypass valve is set properly and water is not flowing back thru it. Something isn't right. I check and the zone valve is working. I even tried it manually. The flow goes up.
    I'm thinking the down stairs tee may be too close to the elbow to the left. I've see the rule of 12d. I can fix this, but do you think that's the problem. I don't want to do that work if it's not the problem. The zone valves are 4d apart.
    Any input would be greatly appreciated.
    Sorry about the photo being sideways. I tried to fix it with no luck. Up is to the left
  2. jadnashua
    It's more common to have air in the higher level, but it doesn't take much to block flow through a loop...first thing I'd do is try to purge air from the system again.
  4. philtrap
    philtrap Member
    Jun 19, 2013
    Civil Engineer
    Long Island, NY
    Thanks jadnashua!! I re-purged again and one large burp and now all is fine now.
Similar Threads: heating upstairs
Plumbing Forum, Professional & DIY Advice Water softener Radiant heating question Mar 6, 2017
Plumbing Forum, Professional & DIY Advice In-wall rated pipe heating cable for PEX Nov 11, 2016
Plumbing Forum, Professional & DIY Advice Help sizing pex-al-pex for hydronic heating Oct 5, 2016
Plumbing Forum, Professional & DIY Advice 11th Asia-pacific Water Heating Exhibition(AWHE 2016) Jun 13, 2016
Plumbing Forum, Professional & DIY Advice Relocation Expansion Tank - Hydronic Heating May 4, 2016
