Heating Basement & Up satires Should you separate heating systems
nhoj
I would like to know if you need separate heating and cooling system for your basement and up satires and if so what would be the bst systems to get?
Dana
In the trades
The heat loss characteristics of basements are very different from above-grade rooms. If not a separate system, it needs to be controlled as a separate zone.
To specify ANY heating solution would require some sort of heat load calculation at the local 99% outside design temp based on the construction type & insulation methods.
