Heater question
Discussion in 'HVAC Heating & Cooling' started by D'Brie, Sep 29, 2009.
  1. D'Brie
    D'Brie Apprentice Plumber
    Oct 20, 2008
    Apprentice Plumber
    NW Washington State
    Hi all,
    I have a Trane natural gas forced air heater for my home (model TDE060A936KZ). It's 12 years old and I am going to schedule it's yearly maintenance soon. I am getting an error code: "pressure switch problem" so my question is; should I replace this unit with a new heater? It's in fine shape, I keep it clean but what is the average age for replacing heaters? Thanks for the time all.
  2. veesubotee
    veesubotee New Member
    Nov 3, 2008
    I would go ahead and schedule the maintenance. It could be a relatively inexpensive fix.
    V
  4. jadnashua
    I'm guessing on this, but that error could indicate the exhaust or intake air ducts have a problem...a hole or obstruction (bird's nest) or something like that could disrupt the air flow to the burner, and it could give that error, so, it might not be an actual furnace problem other than its ability to intake or exhaust air. This could prevent it from firing, which would be a major pain if it got cold. Also, some of these have a vacuum hose to the switch, and the hose may have split (like can happen on your car), preventing the switch from operating. The switch itself could be bad as well. Just like an error code on a car, it's announcing a fault, but interpreting what's causing it takes some skill and understanding of the whole system.
  5. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    12 yrs
    Only 1/4th of HVAC equip. gets replaced that early.
    Call an HVAC supply house and see how much it is for a pressure switch. Some units have Built In Test Equip. and they really mean the switch itself is failing.
  6. D'Brie
    Oct 20, 2008
    Apprentice Plumber
    NW Washington State
    Thanks you guys, I have an HVAC company coming out and we'll get to the bottom of this.
Similar Threads: Heater question
HVAC Heating & Cooling Question about gas heater Oct 18, 2015
HVAC Heating & Cooling Electrical question fir 5 ton pool heater heat pump Feb 28, 2014
HVAC Heating & Cooling Outbuilding/shop heater questions/opinions Jan 8, 2014
HVAC Heating & Cooling question - electric water heater Oct 7, 2013
HVAC Heating & Cooling Baseboard heater cover height question Jul 8, 2011
