heat trap question
Discussion in 'Water Heater Forum, Tanks' started by netmouse, Oct 17, 2013.
  1. netmouse
    netmouse Member
    Aug 7, 2012
    NJ
    This forum supports using the "U" piping for a heat trap to keep hot water from migrating. I understand today's tanks are delivered with heat trap nipples, something Terry and others do not like as they can cause problems. I also believe I heard that if you remove the heat trap nipples from the delivered tank that can cause the plastic to melt at the entrance where the pipes are attached.
    In summary, can the heat trap nipples be removed on the tank delivered, and replaced by the "U" piping? Or just leave things alone as delivered and forget the "U"?
  2. Caduceus
    Caduceus Master Plumber
    Oct 16, 2013
    Just a Plumber
    Pittsburgh, PA
    Most manufacturers will only recommend removal by a licensed plumber for warranty purposes. They can, however be removed and replaced with plastic lined galvanized nipples that are available at some big box stores and plumbing supply retailers. Some plumbers will even use brass nipples. I think there may be some confusion about the melting you mentioned. Melting of the plastic insert of the nipple, and potentially the dip tube of the tank, typically comes from soldering the copper fittings after connecting them to the nipples. It's always recommended to pre-solder the copper female/male adapter on to a piece of pipe approx. 16" long and allowing it to cool before threading it on to the supply nipples on the tank.
    Regardless of the type of nipple used, remember to get some dielectric unions to reduce corrosion to the nipple-to-tank connection.
    I prefer piping the heat trap instead of relying on the nipples as even manufacturers will admit to the noise they cause. If possible, I pipe 12" vertical up, 12" horizontal then 12" vertical down. Adding insulation is a bonus.
  4. netmouse
    netmouse Member
    Aug 7, 2012
    NJ
    You wrote: "I prefer piping the heat trap instead of relying on the nipples as even manufacturers will admit to the noise they cause."
    Are you saying - use the U piping heat trap, and remove the nipples because they can make noise?
  5. Caduceus
    Oct 16, 2013
    Just a Plumber
    Pittsburgh, PA
    Yes. They are well known for causing a mysterious vibration sound in the pipes which can be mistaken for a bad PRV, loose washer in a valve or even a siphoning ballcock assembly. Here is a piece of text copied from the Bradford White website:
    "From time to time there have been reports of these heat traps being noisy. This is usually caused by the pressure of the incoming water causing the balls to vibrate as the water velocity rushes around them. Most people tolerate the noise when they realize the heat traps translate to dollar savings on the electric or gas bill. Heat traps are estimated to reduce heat loss by as much as 12%. If the noise cannot be tolerated, the cold inlet/dip tube and hot outlet/anode heat trap assemblies can be removed and replaced with assemblies that do not have heat traps."
  6. netmouse
    netmouse Member
    Aug 7, 2012
    NJ
    Thank you! Very helpful.
  7. netmouse
    netmouse Member
    Aug 7, 2012
    NJ
    I read the Bradford White text and it ends with this, " Removal of the heat traps, (or the balls in the heat traps) is not recommended by Bradford White, and is not covered under the provisions of our warranty. Please consult a Plumbing Professional for assistance."
    Maybe best to leave heat traps in place unless there is a problem that cannot be tolerated.
Similar Threads: heat trap
Water Heater Forum, Tanks Water Heater Strapping Conundrum Oct 17, 2016
Water Heater Forum, Tanks Do heat traps work? Nov 12, 2015
Water Heater Forum, Tanks Heat traps on new WH? Jul 14, 2015
Water Heater Forum, Tanks Internal Heat Trap Jan 8, 2014
Water Heater Forum, Tanks How effective are heat traps? Sep 27, 2013
