Heat transfer Plates
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by williambonetto, Jan 15, 2013.
  1. williambonetto
    williambonetto New Member
    Apr 13, 2008
    Is there a big difference between the transfer plates that are stamped or the extruded plates. The extruded plates seem thicker so i would think that they would heat the floor a little better or for a longer amount of time. I am talking about between the floor joist heat transfer plates.
    Thank You
    Bill Bonetto
    Bonetto's Carpentry
  2. hj
    What you are concerned about is how fast the heat can get from the fluid to the floor. Thin plates will transfer the heat faster, but also cool down faster when the flow stops. Cast, because it has more mass, heats up slower, but also retains its heat longer.
  4. williambonetto
    Apr 13, 2008
    So is one better than the other? Is there pros and cons of each one? It is for my own home so I would like to got with the better choice.
    Thank You
    Bill Bonetto
    Bonetto's Carpentry
  5. hj
    It is the same question about whether to use cast iron radiators, or baseboard, or fin tube baseboard. Each has its benefits and negatives. Thin plates will heat up faster, but cast will have a more uniform heat, so it is a personal preference.
Similar Threads: Heat transfer
Plumbing Forum, Professional & DIY Advice Heat transfer between water lines? Sep 8, 2004
Plumbing Forum, Professional & DIY Advice Hot and Cold PEX Connections to the Water Heater from Below Thursday at 7:14 PM
Plumbing Forum, Professional & DIY Advice Where to place Tankless Water Heater Condensation Line Wednesday at 12:10 AM
Plumbing Forum, Professional & DIY Advice Issue with new water heater Mar 20, 2017
Plumbing Forum, Professional & DIY Advice Heat Pump Mar 13, 2017
