Heat System wont hold Pressure
Discussion in 'HVAC Heating & Cooling' started by bdryer, Oct 31, 2010.
  1. bdryer
    bdryer New Member
    Oct 3, 2010
    Washburn WI
    2 years ago i built a house on a slab and installed 1/2" pex (******* brand, if thats what it is, i dont recall) tubing to specification, per my plumber friend, in my slab. As a cheap heat system i bought a residentual hot water heater and he helped me with pumps, controls etc. it seemed to work fine. last winter i noticed i had to add water alot. now this winter i go to start it up and i cant get it to fill up and hold pressure. i run it up to 30# and come back in 10 minutes and it goes to zero. i valve off the system supply lines and it holds. i have straight water in the system. its not cold enough yet for them to be frozen. i'm afraid to ask this question...didnt sleep at all last night....but is it possible that some where in one of my runs a line froze last winter and burst and now i cant fill the system???? if so, now what am i going to do??
  2. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Losing one pint of water in 10 minutes may be hard to find but a cubic foot of water will probably make itself known. How much water are you looking for?
    The pinhole leak in my pipe lost a gallon in 3 minutes but that water went into the ground. Still, I could hear the leak 10' away from any pipe.
  4. bdryer
    bdryer New Member
    Oct 3, 2010
    Washburn WI
    I fixed it..
    Well. I think i fixed it. I attempted to determine what run it was that was possibly leaking by valving them all off and opening them one at a time. i expected to find one that would drain the system. After the first run didnt give me a problem i opened the next one and so on. some how i was able to open them all and the pressure stayed up. hmmm. oh well, what ever works ! I happy now. thanks.
Similar Threads: Heat System
HVAC Heating & Cooling Radiant heat and domestic water on same system? Monday at 8:06 AM
HVAC Heating & Cooling "Summerizing" a hydronic heating system May 11, 2016
HVAC Heating & Cooling Multi zones HVAC system not pumping heat to first floor Mar 23, 2015
HVAC Heating & Cooling Adding new radiant heat zones to existing system Feb 21, 2015
HVAC Heating & Cooling Connecting a new radiant heat zone for a garage slab to an existing baseboard boiler heating system Nov 12, 2014
