Heat recovery unit and recirculation piping
Discussion in 'Water Heater Forum, Tanks' started by steelsparky, Mar 16, 2013.
  1. steelsparky
    steelsparky New Member
    Mar 16, 2013
    FL
    While I may not be a plumber, I have been called a freon plumber. I do refrigeration and A/C and just got a deal on a heat recovery unit which uses the discharge line to heat water.
    While I can easily figure out the A/C side of it, I am curious about the water side piping involving the tank. I also plan to add an active recirculation loop from the furthest fixture. And add pump @ tank.
    Question is can someone tell me the correct way to pipe this configuration? Can't seem to find any diagrams on the internet and the HRU I got did not come with any directions. Have a 40gal tank with in, out, and drain port.
    Also can anyone recommend a good grundfos recirc pump? House is on a well.
    Thanks
    Tom
  2. jadnashua
    Exactly which unit did you buy? Sounds like this is using the a/c line to preheat some water. Is there nothing on the manufactuer's website that contains this info?
  4. steelsparky
    Mar 16, 2013
    FL
    I'll have to get an exact model serial but it's a Trevor Martin. And yes it preheats the water. The hru says to tee off cold water supply at the tank and then pipe return into the drain. So I guess my next question is where do I pipe the return for the recirculation loop? Also in the drain?
  5. steelsparky
    Mar 16, 2013
    FL
Similar Threads: Heat recovery
Water Heater Forum, Tanks Gas Heater, Extended Recovery Time, Perceived Low Volume of Hot Water Sep 2, 2013
Water Heater Forum, Tanks Drainwater heat recovery installation Dec 16, 2010
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Wednesday at 10:49 AM
Water Heater Forum, Tanks HW Heater to tankless coil Monday at 8:26 AM
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
