heat pump refrigerant pipe insulation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dave007, May 18, 2006.
  1. dave007
    dave007 New Member
    Feb 14, 2006
    I'm not exactly sure which forum this belongs in.
    I have a heat pump in the back yard.
    Apparently there is some type of black insulation around
    a copper pipe that carries refridgerant to or from the heat pump.
    This insulation is/was held in place with zip ties.
    Anyway, this insulation is old, dried out and is coming apart.
    It appears similar to those big long pieces of black foam
    pipe insulation they sell at home depot...but not exactly the same.
    If anyone has a clue what type of stuff i should get to
    replace the worn out stuff, please post the information.
    The more details (name, price, where to get it, install notes
    etc etc.) the better.
  2. jadnashua
    Look in the yellow pages for a HVAC supply house. Call them to make sure they will sell to you as a retail customer (some are only wholesale). You need something that has some UV inhibitors so it will have chance of lasting awhile. If you could find some pipe insulation with the right inside diameter, it would work, but home centers usually have it sized for water pipes - too big.
  4. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Make sure you only put it on the same line that has it now. Insulating the other line will only reduce your cooling capacity. The line acts as an additonal radiator.
    Jason
Similar Threads: heat pump
Plumbing Forum, Professional & DIY Advice Home run w/PEX how about a heat circulating pump? Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Water heater tank recirculation pump? Nov 6, 2015
Plumbing Forum, Professional & DIY Advice New house, heat and well pump questions Jan 30, 2015
Plumbing Forum, Professional & DIY Advice Hot water heat circulating pump issue Oct 21, 2014
Plumbing Forum, Professional & DIY Advice faulty heating pump question Jan 28, 2014
