Heat Pump Occasionally Emits Cold Air
Discussion in 'HVAC Heating & Cooling' started by Meg, Dec 28, 2011.
  1. Meg
    Meg New Member
    Dec 28, 2011
    Scottsdale AZ
    I have a 9 year old heat pump on my roof (a Trane) that is being temperamental and I would appreciate an experts guidance. In the past few months there have been times when it is emitting cool air when the heat is on and/or it emits hot air when the A/C is on. Sometimes the temp is OK, but it feels like there is very little air at all coming out of any of the vents. A couple of months ago I had an HVAC tech out for an annual check up and described the problem to him. He cleaned the filter and said that the freon was fine. He also suggested that the outdoor fan bearing is worn and a contactor is worn. His recommendation was that, if it got worse, I should replace the motor and contactor. When I try and research the "symptoms" myself via the web, I get very different information. I don't want to be taken advantage of or replace the wrong part and would appreciate some guidance and/or recommendations from other experts in the field. Thank you so much.
  2. jimbo
    jimbo Plumber
    It does sound like a stuck reversing valve, but that is not usually intermittent. It could be a loose wire/bad connection somethere in the B/O thermostat wire circuit.
  4. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    What is Your Model Number ?
    It does sound like the HVAC tech blew some smoke.
    Jimbo's answer sounds a lot closer to me.
    Could also be something as easy as replacing the Thermostat batteries if it is Electronic.
  5. hj
    A heat pump WILL do that when it goes into "defrost/antifreezing" mode to send hot gases through the system to melt an icing condition.
  6. ballvalve
    Dec 28, 2009
    northfork, california
    And furnaces have off delays, some blow a lot of cool air to extract heat from the coil or plenum.
Similar Threads: Heat Pump
HVAC Heating & Cooling Rheem heat pump Nov 27, 2016
HVAC Heating & Cooling Start up noise Heat Pump Aug 21, 2016
HVAC Heating & Cooling Replaced heat pump cap. does it need to charge? Aug 12, 2016
HVAC Heating & Cooling Odd Heat Pump Behavior Feb 3, 2016
HVAC Heating & Cooling Multi zones HVAC system not pumping heat to first floor Mar 23, 2015
