DeweyBeach
My Carrier heat pump is not coming on at all, although the air handler does move air. If I set the thermostat high enough, I get auxilliary (electric) heat, but the outside heat pump itself never activates. Similarly, if I set the system to cool and crank down the temp setting, the air handler starts blowing, but the heat pump doesn't operate. I've checked the fuses on the 240 volt line at the heat pump itself, and both have continuity, and no breakers are tripped at the breaker box.
Any ideas on what the problem might be?
Many thanks.
Many thanks.
