Heat pump fan not running
azbackus
Phoenix
Hi all ... I have a 5 year old Goodman roof heat pump. The fan does not run when I click fan only. When I start the cooling, I can hear the compressor run but the fan will not turn on. I have replaced the dual run capacitor and the Goodman fan delay board. Should I change out the contactor, or is the a fan motor issue.
Thanks,
Bill
azbackus
Phoenix
I activated the contactor and all worked except the fan. However, I think I am using the wrong nomenclature. I am speaking of the blower not working. The compressor and outside fan are working fine. It is the inside fan (blower) that is not working.
Bill
The air handler's circulation fan should be triggered when the thermostat tells it to, or when its logic board realizes you have called for heat or cooling. Not all thermostats are wired nor air handlers setup to allow a manual fan on function, but many do. If the fan does not come on in either situation, first thing to check is the thermostat (manual fan on) and see if that gets the 24vac signal to the air handler. It could be lots of things; wiring, thermostat, air handler, fan, relay...
azbackus
Phoenix
The thermo cap is leaking and needs to be replaced. When I bypass the cap, the motor turns well, but it is hot to the touch very quickly. That must be what blew the cap. It appears I need to replace the motor and thermo.
Thanks for your help,
Bill
