heat pump buzzing
Discussion in 'HVAC Heating & Cooling' started by gfe76, Oct 28, 2007.
  1. gfe76
    gfe76 New Member
    Dec 19, 2004
    Florida
    Tried to search this, but no luck. Atlanta area, central Hvac, heat pumps oustide, air handlers in basement and attic. Yesterday temps around 75 and heat pump condenser "buzzing" but fan not moving. thoughts? thanks
  2. jadnashua
    Main contactor? If the compressor was trying to run and was stalled, it would likely either overheat or overload and pop the breaker. If the fan is shot, it, too would likely overheat. It might not draw enough to pop the breaker, but it would sure start to smell nasty. Once you smell burned electrical wiring, you don't forget the smell.
  4. gfe76
    gfe76 New Member
    Dec 19, 2004
    Florida
    no breaker tripped. It seems to be running fine...it just "buzzes" every so often...do you think it is about to fail? thanks
  5. jadnashua
    It could be as simple as something loose and is a sympathetic vibration, or something more serious. Hard to say without being there.
Similar Threads: heat pump
HVAC Heating & Cooling Rheem heat pump Nov 27, 2016
HVAC Heating & Cooling Start up noise Heat Pump Aug 21, 2016
HVAC Heating & Cooling Replaced heat pump cap. does it need to charge? Aug 12, 2016
HVAC Heating & Cooling Odd Heat Pump Behavior Feb 3, 2016
HVAC Heating & Cooling Multi zones HVAC system not pumping heat to first floor Mar 23, 2015
