Heat Pump-Air Handler question
Discussion in 'HVAC Heating & Cooling' started by jfls49, Nov 9, 2012.
  1. jfls49
    jfls49 New Member
    Nov 9, 2012
    Prospect, PA
    I have a 12 year old Bryant Heat Pump, 10 Seer, 3.5 ton. The reversing valve is crap. Right now I am running the heat in Emergency mode (electric furnace) until I fix it.
    Ive been on www.ingramsairandwater.com and located a 13 SEER 3.5 ton Goodman unit with matching air handler. My question: is it reasonable to go with same 3.5 ton system I had before without going to all the trouble to do a load calc on the house if I am getting the air handler with the variable speed fan? Wouldn't the variable fan speed settings allow me to program the desirable cfm moving through the house.
    Thanks for any advice
    Jfls45
  2. jadnashua
    Without running some calculations, it's impossible to say, but 3.5T would heat and cool a quite large house. In the summer, was the humidity level in the house comfortable? If it got cold, but it was still clammy, that's an indication that the unit is oversized. A variable speed air handler helps, but that can't overcome an oversized unit's short cycling if it is oversized.
Similar Threads: Heat Pump-Air
HVAC Heating & Cooling Radiant heat and domestic water on same system? Feb 13, 2017
HVAC Heating & Cooling Apollo hydro heating Jan 30, 2017
HVAC Heating & Cooling Heater Jan 28, 2017
HVAC Heating & Cooling Relocating thermostat to allow heating with wood stove? Jan 17, 2017
HVAC Heating & Cooling Is my AC Heater bad or the outlet? Jan 15, 2017
