heat exchanger
Discussion in 'Boiler Forum' started by mxlord, Dec 12, 2012.
  1. mxlord
    mxlord New Member
    Dec 11, 2012
    NY
    O.K I just got done building a wood boiler/ furnace for my garage and I have a couple questions. First one is, I made My own heat exchanger with a fan mounted behind it. What is the switch called that mounts to the copper pipe that turns the fan on when it senses heat in the pipe? Second can I use this HONEYWELL HEAT ONLY THERMOSTAT MODEL CT410B to turn on the circulator pump when the thermostat calls for heat? Any help or advice would be great. Thanks..
  2. jadnashua
    A water temperature sensing switch is called an aquastat. To be safe, you need lots more controls than you are discussing...
    Let's say you have the wood boiler running, but no call for heat. If you just let it sit there, you'll start to generate steam and blow things up! So, you may need to run the circulator constantly, and maybe dump the heat somewhere if the house doesn't need it. Trying to roll your own can get you in trouble with your insurance company, your building inspector, and your life...not counting blowing up your house.
  4. mxlord
    mxlord New Member
    Dec 11, 2012
    NY
    I have a aquastat that runs blower to get the fire burning. that is the problem the circulator pump runs all the time and the fire cant keep the water warm enough, it runs about 140 unless i unhook the pump. the water gets to 170 then the blower shuts off and the water stays right around 170. I really just need a thermostat that will run the circulator pump.
  5. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    The problem you will have is when the thermostat is satisfied and the circulator stops running with the fire burning the boiler will over heat causing a dangerous condition.
    John
Similar Threads: heat exchanger
Boiler Forum What caused this on heat exchanger on peerless hydronic boiler? Oct 6, 2016
Boiler Forum Recurring air in zone or crack in heat exchanger? Mar 9, 2015
Boiler Forum EK system 2000 - internal plate heat exchanger leak? Feb 2, 2013
Boiler Forum Heat Exchanger issue with Viessmann boiler Dec 12, 2011
Boiler Forum Consequences of removing basement heat exchangers on a FHW system? Dec 23, 2010
