parity_check
Hey guys,
I'm installing my new gas water heater. The local Home Depot sells 3/4" Everbilt flex steel connectors. They seem sturdy enough but I can clearly tell the the inside diameter is smaller than a straight 3/4" copper pipe. Will this impact my flow? I have a shower on my 3rd story of my townhome and don't want a weak shower or a slow tub fill. My PSI is pretty good and averages around 60 at the ground level where the water heater is.
I looked at the sharkbite and they are even narrower! so I will either sweat copper directly to the dielectric nipples or go with the steel connectors.
Why does nobody mention issues with flow regarding these connectors when they clearly appear that they would cause issues?
Maybe I over thinking this but I like doing things right one time.
Thanks.
Thanks.
