Having trouble connecting 3/4" copper pipe to 3/4" fittings.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cyelrah1, Mar 19, 2013.
  1. cyelrah1
    cyelrah1 New Member
    Mar 15, 2013
    Livermore, CA
    Hi. I'm a beginner DIY whole house copper re piper. I have some experience with re piping and I've practiced soldering sections before beginning the job. I am aware that the pipe that is to be soldered needs to be cleaned to a bright finish, wiped off and fluxed before soldering. My problem is that I am have trouble with the simple task of connecting 10' sections of 3/4" copper to unions and 90 elbow's. The connections seems really tight and have to be worked on by turning back and forth. I'm afraid the connections are so tight that the solder won't flow properly. I bought the pipe sections at Orchard Supply and the fittings at Lowe's, but that shouldn't make a difference..........should it? Thanks
  2. Terry
    Aug 17, 2004
    If you can get the 90's and couplings on the pipe, your're fine.
  4. cyelrah1
    cyelrah1 New Member
    Mar 15, 2013
    Livermore, CA
    Thanks Terry, Any tips on securing copper to floor joists? I have copper plated hanger. Will the pipe be noisy when water is flowing?
  5. DougB
    DougB Member
    Jun 19, 2010
    Software Developer / Engineer
    Minneapolis - Land of 10,000 taxes
    When you have trouble with copper tubing and fittings, it's probably that the tubing was mishandled, and it's a little out of round. Before I buy tubing I make sure that a sweat coupling fit's easily - if not I try another piece of copper.
    The single ear / double ear straps are OK.
  6. hj
    It would be almost impossible for a copper tube and fitting to be so tight that the joint would be defective. IF they were too TIGHT, you would not even be able to get the tubing inserted. But, they can be too LOOSE to make a good joint. A sweat joint depends on a close connection between the tube and fitting.
Similar Threads: Having trouble
Plumbing Forum, Professional & DIY Advice Having Trouble Venting Bathroom Renovation Oct 26, 2016
Plumbing Forum, Professional & DIY Advice Having trouble installing garbage disposal: May 20, 2015
Plumbing Forum, Professional & DIY Advice Having trouble getting Original Toto Flapper THU092-7, really, seal gasket alone would be fine Feb 10, 2015
Plumbing Forum, Professional & DIY Advice Having Trouble Removing Vanity Sink Altmans Faucet Flange Jun 8, 2014
Plumbing Forum, Professional & DIY Advice Considering having a plumber examine my vent stacks. Yes or no? Nov 22, 2016
