Golferdude1977
I am looking for someone to drill my well but wanted to have a better picture of what I needed before talking with the drillers.
I have looked up the well records of several people around me so I have an idea of what my well might look like:
well 1 is my neighbors: 620 feet deep, 400 feet is the static level, and estimated gpm is 200.
well 2 is just down the street: 605 deep, 310 feet is the static level and estimated gpm is 100.
My house is 2.5 baths, 2300 sq ft. My irriation system is currently set up with 10 zones, each zone is using 8.5 to 9 gpm. I would love to boost the gpm's to 12 or even 15 gpm so I could reduce how long I have to water. My monthly water bills are using about 54,000 gallons a month with about 4000 of that house use.
I really like the idea of using a CSV type system. I have seen alot of drillers around here using a constant pressure system. So I want to learn more on the CSV and components needed to make it work.
With the irrigation system, will I need a booster pump to keep the volume and pressure up where I need it? From what I have read, it looks like anytime the irrigation system is running the pump will run. I know when the well is drilled I want them to run a draw down test to see what kind of drop it has. I usually irrigate the entire yard twice a week, might have to break it down and water half one night the other half another night and do that twice a week to reduce the draw down.
I tried to figure out things I might need and started getting confused so any suggestions would be appreciated.
