Have you seen this screw/faucet?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by amoncarter, Jul 13, 2010.
  1. amoncarter
    amoncarter New Member
    Jul 13, 2010
    dfw
    Hi Y'all
    I am hoping someone of the forum has seen my type faucet before.. I have several of these that are leaking and am looking for help identifying the faucets. There are some at 4inch and some at 8inch, but with identical handles/screws (see below) - so a safe bet that they are the same company.
    the large ones (not pictured) actually say Delta in the front - but Delta customer service cannot identify the faucets.
    They all have a hex head (color coded to water temperature) screw in the handle - and most of mine have been stripped by someone using a Philips instead of an allen wrench before I got there.
    Questions:
    1. Can anyone definitely identify these as Delta (in which case their generic seat/spring will work)
    2. Any ideas on the screws - I can't seem to find anything on color coded hex head screws..
    3. Is the colored screw just to indicate temperature and should I be looking for a hidden set screw or some other way to take off the handle?
    Thanks/Micky
  2. hj
    Pull the handle that you removed the screw from and take a picture of the stem underneath it. THAT will be a better indicator of the manufacturer than the handle or screw.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Moen has a commercial lav that uses colored TORX screws on the handles. It would help a lot if you took out the cartridge and posted a pic of what's inside that faucet. If it is seats and springs, delta parts probably work no matter who made it.
  5. amoncarter
    Jul 13, 2010
    dfw
    Closure
    Thanks for all the help - Delta seat/springs worked. The aluminum red/blue screws are special order.
  6. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    If you aren't worried about somebody stealing the handles, just use a regular slotted or phillips head handle screw.
