Have you seen this faucet?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rminv, Jul 11, 2010.
  1. rminv
    rminv New Member
    Feb 7, 2009
    Has anyone seen this faucet? I think it might be a Price-Pfister.
    I tried to take off the handle the other day. I began by trying to pry the chrome 'cap' off the top - only it turned out not to be a cap. You can see the result in the attached image. I ended up peeling off the top surface of the handle. There is a center circle (where I thought the screw would be) that remained firmly attached to the rest of the handle.
    I'm sure I'm being an idiot, but does anyone know where the retaining screw for the handle is on this model?
    Thanks,
    Tim
  2. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    It is a Price Pfister and IIRC there is a small tab near the base that you push in and then pull up on the handle
  4. rminv
    rminv New Member
    Feb 7, 2009
    I don't see a little tab. Do you recall how to uncover it?
    Thanks for the reply,
    Tim
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  6. hj
    That piece you "tore apart" would have unscrewed from the handle if you had used a pair of Channelock pliers on it. That small "circle" in the center is where the thread is, and the retaining screw is UNDER it. You used the "don't force it get a bigger hammer" theory on it, and now it is trashed. I hope you are replacing the valve, because you will probably NOT find a new handle or cap any more.
  7. rminv
    rminv New Member
    Feb 7, 2009
    Yep, I knew I'd feel like an idiot. Right answer, HJ. You guys are awesome. Thanks!
    Tim
Similar Threads: faucet
Plumbing Forum, Professional & DIY Advice Please help identify this faucet brand TY Tuesday at 3:53 PM
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Monday at 9:32 AM
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
