Have autotrol 440I timer control not working
Discussion in 'Water Softener Forum, Questions and Answers' started by rob742, Jun 3, 2013.
  1. rob742
    rob742 New Member
    May 17, 2013
    Pennsylvania
    Hi I have a Autotrol 440I Timer control for Model AF 263-2D acid neutralozer.
    The regeneration cycle is not strarting on the programed time. I set the correct Time but when I check the time again it is always way off. How hard is it to replace the timer? Or could it just be the motor?
    Whay do I have to do to remove the whole 440I assembly?
    Thanks Rob
  2. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    The timer is very easy to remove. Simply remove the "flag" on the lower left side of the timer and pull up. It could be a gear broken or the motor. You can remove the motor and see if it's turning. If it is, the timer cover can be removed to check the gearing. Softenerparts has different replacement gears.
  4. rob742
    rob742 New Member
    May 17, 2013
    Pennsylvania
    Do I need to put the tank in bypass first and release any pressure in the valve assy before I remove the Timer ?
  5. rob742
    rob742 New Member
    May 17, 2013
    Pennsylvania
    Also do you know what the odds are that it is the motor. Or from experience do the gears break more often?
  6. mialynette2003
    Nov 24, 2010
    Ocala, Florida
    Yes it is best to put the unit on bypass. The gears are a weak point on the Autotrol valve so it may be more likely a gear is broken. Both are very easy to see so you can check them before ordering parts.
Similar Threads: autotrol 440I
Water Softener Forum, Questions and Answers Autotrol 255/440i water low flow and brine tank backing up Jan 13, 2013
Water Softener Forum, Questions and Answers Have quotes for Fleck 7000sxt and Autotrol 268-760 Sep 22, 2016
Water Softener Forum, Questions and Answers Autotrol valve advice needed Apr 14, 2016
Water Softener Forum, Questions and Answers Autotrol 740 timer 7-day mode Mar 24, 2016
Water Softener Forum, Questions and Answers Is Autotrol both a valve and a water-softener unit? Jul 27, 2015
