Have 14 inch rough in, can I install Toto Drake and just leave a gap in the back?
Discussion in 'Toilet Forum discussions' started by Kathy from CA, Mar 20, 2006.
  1. Kathy from CA
    Kathy from CA New Member
    Mar 19, 2006
    Hello all,
    I am a novice and would like to thank all of you who contribute to the
    forums. Lots of great information and advice here.
    Remodeling an old bathroom, toilet has a 14 inch rough in, and because the room is small, only a round bowl will fit. I have no experience in changing
    toilets and am trying to educate myself. Is there any reason why we can't
    install a Toto Drake, round bowl, 12 inch rough and just leave a 2 inch
    gap between the wall and the tank? We were planning to put a small
    shelf above the tank and the gap wouldn't be obvious. Thanks in advance
    for your advice.
    Kathy from CA
  2. hj
    toilet
    As long as the toilet will fit over the opening in the floor and you are happy with the way it looks, you can install a toilet with as much space behind it as you want. I have had customers want 6" behind the toilet so they could put a shelf unit above it.
  4. jadnashua
    Or you could get something like the Toto Vespin or Carlyle with the 14" unifit adapter...even the elongated bowl would use less room than a standard one with 2" behind it.
    [​IMG]
    Toto Vespin II CST474CEFG with SS114 Softclose seat.
    This bowl was installed on a 13-1/2" rough-in using the 14" Unifit adapter.
    The water shutoff can be as close as 5-1/2" to the left of center, unless it's higher off the floor, and then it can be even closer to center.
    This shutoff had been replaced with a new 1/4 turn valve with brass nipple through the wall.
    Installation was by James Love of Love Plumbing & Remodel 206-949-5683
    In some of the older Seattle homes, the old toilets had been wall mounted tank toilets.
    Those typically are 14" rough-in and need a flange repair to use standard closet bolt connections at the flange.
    Everything is on the truck for that.
    The Vespin comes with a standard 12" adapter or you can order a 10" or 14" adapter depending on your rough-in distance.
Similar Threads: inch rough
Toilet Forum discussions Only 8.45 inch rough to replace American Standard 4049 Jul 10, 2016
Toilet Forum discussions Need Advice: 10-inch rough-in for small space Apr 23, 2016
Toilet Forum discussions 14-inch Rough-In. Standard hight like 14 to 14.5 inches what toilet? HELP! Mar 27, 2016
Toilet Forum discussions Ten inch rough. Dec 20, 2015
Toilet Forum discussions 13-Inch Rough In Question for Toto Soirée Nov 30, 2015
