Hardie Backer Shower Ledge Question
Discussion in 'Shower & Bathtub Forum & Blog' started by acruz, Jun 20, 2014.
  1. acruz
    acruz New Member
    Jun 20, 2014
    FL
    I am redoing my shower with a 2x4 ledge which drops down on one side 5" into the shower. I plan to put 1/2 inch Hardie Backer on the ledge, cover it with Red Guard, tile it, then have a glass wall installed up to the ceiling ledge. Do I need to use fiberglass mess with thinset on the edges of the ledge?
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    I'm doing open heart surgery in the morning. Do I need a scalpel?
    Your question is so vague - hard to answer at all.
  4. acruz
    acruz New Member
    Jun 20, 2014
    FL
    Hardie Backer Clarification
    Here is some more clarification. I have a slab floor and attaching a 2x4 ledge with Tapcons into the slab in a corner of my bathroom where the shower was. In the shower area is my on grade slab, which then meets my 2x4 ledge. This ledge then drops down about 6.5 inches into the below grade (currently) cement shower floor. I plan to put Hardie Backer on one side of the ledge, the top of the ledge, and the other end where it drops 6.5 inches into the shower floor. It will be covered with Red Guard and then tiled. I am assuming I need to use fiberglass mesh with thinset on the corners of the ledge where the sides meet the top. Is this correct?
  5. RedShoecounterbalance
    RedShoecounterbalance Stay away from ladders
    Apr 7, 2014
    keep Jim in line
    Minnesota
    Acruz, show us some pics? You always need to tape and thinset your joints/changes of plane with cbu. Read mfg imstall specs and follow.
    You will then redgard after proper drytimes are met.
    Again read mfg install guidelines.
    However , your ledge sounds concerning, pics help!
    - redshoe
  6. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    I second the picture request.
    Since no one else has said it I will. I think Red Guard sucks. I would not use it as a primary shower pan liner. I would not use it in any change of planes. If I was forced at gun point to use a liquid I would use Mapei's AquaDefence - only because the product has something called Mapeband - a flexible corner band.
    I would not use any liquids over thin-set or concrete that is not 28 days old.
    I would leave the liquid to cure out a week before floor testing.
    I would not use a 2"x4" on the slab. That is juts wrong to begin with.
    Like I said before your question is vague. Post a picture.
    Is this a barrier free shower build?
    What is your primary shower waterproofing?
    Do you have a pre-slope?
    Are you going to flood test?
Similar Threads: Hardie Backer
Shower & Bathtub Forum & Blog 1/4 HardieBacker Board for Walls? Jul 13, 2013
Shower & Bathtub Forum & Blog FIBEROCK Tile Backerboard vs HardieBacker Cement Board Mar 15, 2013
Shower & Bathtub Forum & Blog Use of 1/4 inch Hardie backer board on tub surround Feb 1, 2011
Shower & Bathtub Forum & Blog Hardiebacker vs Greenboard Mar 16, 2010
Shower & Bathtub Forum & Blog Countersinking Backer-On screws in Hardiebacker? Jan 26, 2009
