Hard Water Leaking
Discussion in 'Water Softener Forum, Questions and Answers' started by shanlar, Sep 12, 2011.
  1. shanlar
    shanlar New Member
    May 22, 2011
    Elk Grove, CA
    Ok I am having an issue with hard water getting past my water softener. I have a Clack WS1 with the Clack Bypass. Riser tube is flush with the tank threads, 1.05" tube size, and the seal on the bottom basket appears bonded well. I do have a top basket as well.
    At the faucet I have about 15 hardness and from a hose outside I have a hardness of 25 hardness. I decided to verify my water was truly soft by going straight to the source. Over the weekend I drained the resin tank and sampled the water at the bottom. Tested perfectly, 0 hardness. I reseated the riser tube by attaching a garden hose and pumping it full of water while pushing it down.
    So it looks like some how hard water is mixing with the soft water. From what I have read here, the possibilities would be either the bypass or the valve itself. The bypass did leak a bit on top where the handle/arrows are, but that leak stopped within a few hours. Does anybody have tips of how to verify which one is leaking the hard water? I do not want to RMA the wrong part, just to turn around and RMA the correct one.
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Have you talked with the company that you bought the unit from?
    Another reason for untreated water at the faucet could be low flow and slippage through the resin.
    The system could be over sized or under sized..
    If it is an o ring or seal in the main body there is every chance that it is not under warranty ... as that is the water taking out the seals or o ring.
    Now I might be wrong, but the above are just my thoughts on the matter.
  4. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    Put the unit in a settle/rapid rinse. Test the drain water. If you have soft water at the drain, the bypass is leaking by. If not, the valve or the sealing point at the distributor tube is at fault.
  5. shanlar
    shanlar New Member
    May 22, 2011
    Elk Grove, CA
    I bought the parts from out of state and had them shipped to me. If need be I will call a plumber out, but where is the excitement in a DIY project if you call in the pros to finish the job the moment it gets rough! :)
    Can you explain how slippage through the resin works? Since the bottom of the tank had soft water, I would think that means slippage hasn't occurred? Could be my thinking is just wrong on this matter.
    My system is a 2.0 cuft. House is 2,900 sq ft with 2 people using ~90 gallons per day each, according to my water bill. Hardness is 25.
  6. shanlar
    shanlar New Member
    May 22, 2011
    Elk Grove, CA
    settle/radid rinse, would this be the backwash mode you are referring to? If so, you are saying to go into regen mode, skip all the way to backwash, and then test the drain water for hardness?
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    Pressure loss or hardwater slippage usually indicates more frequent backwashes are required, another term that could be used for slippage would be the flow of water through a limited number of passages in a softener letting untreated water into the house.
    Is that 180 gallons with or with out the out side hose hook ups?
  8. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Is slippage the same as water softener channeling? Could media fouling lead to it?
  9. mialynette2003
    Nov 24, 2010
    Ocala, Florida
    No. Backwash lifts the resin so hard water will definitly slip through. The settle/rapid rinse goes down through the resin packing it down. The raw water has to pass through the colum of resin which will soften the water. If you have partly hard water at the drain, then you have a leak by in the valve or distributor tube sealing point.
  10. shanlar
    shanlar New Member
    May 22, 2011
    Elk Grove, CA
    If this was happening, wouldn't the water at the bottom of the tank have hardness? When I took the valve off, I used a PE tube all the way down the riser tube and drained the water out like a water bed. This water tested at 0 hardness.
    We do not use the hose hook ups outside very much; maybe once a month. Our usage per day is really 95 gallons each, but I subtracted 10 gallons a day off the total for irrigation of my small lawn.
  11. shanlar
    shanlar New Member
    May 22, 2011
    Elk Grove, CA
    I will attempt this tonight, I am assuming this is the rinse cycle on a Clack valve.
  12. chevy427
    chevy427 Banned
    Nov 20, 2010
    USA
    There are two types of channeling. One that occurs during backwash and one that occurs during service. Very often channeling happening long enough during the backwashing stage can cause channeling during the service stage. Channeling is the opposite of 'pistoning' for backwashing.
    And yes, channeling can lead to fouling, but the opposite can also happen. Either way, it should be avoided and corrected.
  13. shanlar
    shanlar New Member
    May 22, 2011
    Elk Grove, CA
    Rinse cycle has 0 hardness. I am going to submit to RMA the bypass as it is only a month old and see if that fixes my issue.
    Thanks and I appreciate all of the help in this thread!
  14. mialynette2003
    Nov 24, 2010
    Ocala, Florida
    Please keep me posted. Could be a problem that would save time and money for me.
Similar Threads: Hard Water
Water Softener Forum, Questions and Answers What causes water hardness to increase? Does pump depth affect it? Dec 28, 2016
Water Softener Forum, Questions and Answers Softener for hard well water Oct 30, 2016
Water Softener Forum, Questions and Answers Discussion: Compensating SFR for high hardness water? Aug 20, 2016
Water Softener Forum, Questions and Answers Hard water with iron looking for advice Aug 4, 2016
Water Softener Forum, Questions and Answers Water harder after regeneration? Apr 16, 2016
