Hard seat and soft seat
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dx, Oct 22, 2010.
  1. dx
    dx General Contractor
    Jul 4, 2005
    General Contractor
    Michigan
  2. jimbo
    jimbo Plumber
    Hard seat means metal to metal contact. A soft seat would have a seating surface with a rubber gasket, or maybe a teflon ring, or such.
  4. hj
    When it comes to check valves, a soft seat will not make as much noise when it closes. The hard metal to metal contact of the hard seat can cause be quite loud, especially if there is a lot of back pressure "slamming " it shut. The hard contact can also cause it to "rebound" creating a chattering noise.
  5. dx
    Jul 4, 2005
    General Contractor
    Michigan
    Thanks guys. Related question: some swing checks are labeled "for horizontal installation only". I do understand why. But why aren't all of them labeled that way? Can some of them be installed vertical or is it just that some manufacturers fail to label them properly?
  6. hj
    I cannot imagine why they would be labled that way, since gravity and the weight of the liquid would close them in a vertical orientation. When they are installed horizontally, some have a label to show which side should be on top, because the hinge location is not obvious.
Similar Threads: Hard seat
Plumbing Forum, Professional & DIY Advice How to get hard plastic piece out of the drain? Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Shower drain relocate. Which is harder? Nov 16, 2016
Plumbing Forum, Professional & DIY Advice How hard to replace sight glass on old pressure tank Oct 22, 2016
Plumbing Forum, Professional & DIY Advice Need advice. replair or replace shower/tub hardware. Now? Later? not at all? Sep 25, 2016
