Hansgrohe Shower High Temperature
Discussion in 'Shower & Bathtub Forum & Blog' started by mattfred, Oct 24, 2009.
  1. mattfred
    mattfred New Member
    Oct 24, 2009
    chicago
    I moved into a place this summer and the shower had a pretty low maximum possible temperature. The faucets and other showers get plenty hot, so I'm not concerned with the heater. Now that its starting to get colder, I'd like my shower to be a little bit warmer. Its a hansgrohe 04908 (I think). I removed the face plate and handle after I found some instructions to adjust the temperature on the internet, but my plumbing doesn't look like the instructions and I can't seem to find any that look like what I have.
    I've attached a picture of the instructions and of my shower. Can anyone help me adjust the maximum temperature?
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Thermostatic valve
    It never surprises me how many faults we find in all these High End fixtures.
    You need to contact the techs direct from the manufacture or if you can source a plumber familiar with these units that would be easier.
    What is the best store in your town to buy plumbing fixtures. Call them and ask for there senior most sales member. Ask them who to call.
    Good Luck
  4. jimbo
    jimbo Plumber
    Remove that screw and see what is under.
  5. jadnashua
    It looks like you may have an expansion kit on the valve and that may be complicating things. It may become obvious if you remove that cap and screw.
  6. mattfred
    mattfred New Member
    Oct 24, 2009
    chicago
    I don't have access to the water main and I was afraid to remove that end piece without turning off the water. Do you think it will be okay? I gave it a little bit of a twist, but the screw didn't budge, so I was afraid it was under pressure.
  7. WorthFlorida
    WorthFlorida USCG escorting cruise ship leaving Port Everglades
    Oct 28, 2009
    Retired
    Orlando, Florida
    The picture shows a stem in the left side of the valve body. This is the shutoff for the hot water side. There should be one on the other side for the cold water. Usually a 1/4 of a turn will shut off the water then you can open up the valve.
  8. WorthFlorida
    Oct 28, 2009
    Retired
    Orlando, Florida
    Another look at the picture and the slot for a screw driver should be in line with the holes within the shut off valve. It shows that it is slightly up and not parrallel to the body. Try turning it clockwise to fully open the valve then check the hot water flow.
  9. mattfred
    mattfred New Member
    Oct 24, 2009
    chicago
    I got it fixed. Thanks a bunch. I shut off both the hot and cold water which gave me the confidence to open the top part. From there it was pretty obvious. Thanks a lot for all your help.
  10. PeterGoose
    PeterGoose Actor
    Nov 17, 2009
    Actor
    Glendale, CA
    Samer HansGrohe Heating Problem
    So, I sem to be having the same problem as MattFred, but mine is slightly different. The hot water works well in all fixtures except the shower. My setup is a little different inside. I have the same center spindle WITHOUT a stop collar. Also my hot and cold adjustment screws DO NOT turn off the water (I'm sittinh here drenched as I write!). There doesn't seem to be any way of mmanually adjusting the spindle any higher to provide more hot. If I unscrew the large nut behind the spindle there is no cap, just a large opening. I don't know if my unit is older or newer than Matt's, but I guestimate it's about 4-5 years old.
    Any Help???? Thanks!!!
  11. EuroPlumber
    EuroPlumber In the Trades
    Mar 4, 2009
    Tech Support
    North America
    Hansgrohe valve
    The first guy in this thread was trying to work on a PBV with instructions for a Thermostatic valve.
    The next one sounds like an older Ecostat model, which has filters. You need to clean the filters on the thermostatic cartridge. If you have service stops with screw driver stops, you can contact Hansgrohe and they will send you the latest version. This replaces all of the old working parts with a better design and less filtration which is a good thing. Best of all they won't charge you for it and you will end up with a brand new shower valve. Replaceing the old with the new is easy, but you will have to turn off the main water supply to do it.
    Hansgrohe's number is 800-334-0455
Similar Threads: Hansgrohe Shower
Shower & Bathtub Forum & Blog Hansgrohe shower head squeeling like a banshe Dec 11, 2015
Shower & Bathtub Forum & Blog Need help with Toto vs Hansgrohe Shower fixtures Oct 6, 2015
Shower & Bathtub Forum & Blog Hansgrohe shower valve cartridge replacement issues Jul 31, 2014
Shower & Bathtub Forum & Blog Shower schematic for Hansgrohe or Moen hand-shower, shower head and rain shower Jun 5, 2014
Shower & Bathtub Forum & Blog Acrylic tub installation with Hansgrohe tub shower valve May 1, 2014
