Hanger location
Mike kelly
Chicago, IL
is there a formula to figure out where to place a hanger for a branch line coming off of a wye..... there must be a measurment off of the center of the main depending on the distance of my first hanger off the wye
Sylvan
Still learning
New York
Clevis hangers shall be spaced according to type piping materials (cast iron, steel, copper, plastic ) and by the size of the piping
It is all available by looking at your local code book
The better codes even state what size rod (threaded) to be used
By the way hub cast iron was spaced behind each hub and every 5 feet
Cacher_Chick
Test, Don't Guess!
There is always a maximum spacing allowed between hangars, which as mentioned, varies depending on what kind of pipe you are installing. It is never wrong to install extra support.
