Handle Replacement options
Discussion in 'Shower & Bathtub Forum & Blog' started by jerome8283, Sep 25, 2008.
  1. jerome8283
    jerome8283 New Member
    Oct 4, 2006
    New York
    Hey guys,
    I would like to replace my shower/tub handle. It's a standard single Moen handle, it pulls to turn on the water, left/right -- hot/cold and pull stem on the spout to turn on the shower. I would like a lever handle if possible. What are my options? I've attached pics.
  2. jimbo
    jimbo Plumber
    You do not have a lot of options, but there may be some. Moen used to have a lever handle option available for that Legend series valve. I don't know if they still make it., but an aftermarket company may. Take your handle and escutcheon plate into a large pluming store ( NOT a home store). They should be able to help.
  4. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    It's funny i switched my Moen handle to lever from Moen's trim kit and the weight of the lever actually turned the valve back to the center.
    I think because the handle was so heavy and the cartridge is that plastic piece of &*^!.
    So be careful unless your like the temperature of the water at the center.
  5. jerome8283
    Oct 4, 2006
    New York
    Which trim kit?
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Go to this link and plug in the info in the pull down menus to see what trim parts are available there are...
    There are 9 with levers and 10 with knobs for you to select from.
    Click here for Moen replacement parts.
    The problem peanut mentions is a possibility with the levers and a new (loose) cartridge.
  7. jerome8283
    Oct 4, 2006
    New York
    I went there earlier but what's not clear to me is do those kits at that link require that I replace the cartridge or any of the plumbing?
  8. Redwood
    Dec 15, 2007
    Service Plumber
    No the basic valve is the same.
    You just need to find your valve and the associated part numbers for the trim and knob then compare to what you want to have and install the differing parts.
  9. hj
    Moen
    Moen has many different trim kits available, but you have to choose from the Chateau or Moentrol line.
  10. jimbo
    jimbo Plumber
    The devil is in the details. I think your Legend has the escutcheon screws at 5 and 7 oclock. I dont think they have any trim for that. The Legend Moentrol has screws at 2 and 7.
    All the valves on the website labeled as "PosiTemp" : NONE of those parts will fit your valve at all.
  11. Redwood
    Dec 15, 2007
    Service Plumber
    If the questions with the pulldown menus at that link are correctly answered only the proper valves will show up. The exception being the answer for "does your faucet have a knob or lever?" That you would have to answer lever to see what you want.
  12. shaolin_dragon
    shaolin_dragon New Member
    Oct 6, 2006
    VA
    Moen does make a trim kit for the standard valve. it is a Monticello style model T2529 (tub/shower) or T2524 (shower only). This is a direct trim kit that will attach to the wall, providing the screws are definitely at 5 & 7. Legend as far as i know, does have them.
    This is the spec sheet for the above trim kit.
    http://www.moen.com/shared/pdf/T2529sp.pdf
Similar Threads: Handle Replacement
Shower & Bathtub Forum & Blog Need help finding replacement tub/shower handle with pushbutton diverter Jun 3, 2014
Shower & Bathtub Forum & Blog replacement shower handle with hex adapter??? Jul 26, 2013
Shower & Bathtub Forum & Blog Pfister 3 handle shower replacement Jul 4, 2011
Shower & Bathtub Forum & Blog Help find a replacement handle/faceplate for Price Pfister Shower Valve. Jul 21, 2010
Shower & Bathtub Forum & Blog Delex replacement handle Aug 3, 2008
