Handheld Shower Question
Discussion in 'Shower & Bathtub Forum & Blog' started by priceman, Dec 4, 2013.
  1. priceman
    priceman New Member
    Dec 4, 2013
    NJ
    Hello
    I am in the middle of a new DIY bathroom remodel and have a question regarding a handheld shower to be used next to the shower bench. I already installed the main shower valve which is to used for the shower head only. I roughed plumbed on the side wall next to our shower bench to accept a handheld/bar system shower sprayer.
    I am having trouble finding exactly what I need.
    Basically I want to mount the handheld shower to the side wall. I would like a simple turn on/off, hot/cold diverter valve. I would to use the plumbing I already have in place.
    Can anyone point me in the right direction. I appreciate your help. I am a novice learning step by step.
    Thanks
    Frank
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Does your shower fixture allow for one or two shower heads to be used? If not you may need to buy a flow valve or two or a divertor valve that can let you choose between the shower head or the hand held - or both.
    Frank have a read if this Ideabook I wrote for Houzz. it describes a lot of these design layout challenges.
    How to place your Shower Controls for Bathing Bliss
  4. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  5. priceman
    priceman New Member
    Dec 4, 2013
    NJ
    If I purchase a 2 way shower diverter valve with the trim kit, can I still route the shower head straight up as normal. Then can I attach pipe to 2nd valve of diverter and pipe it to the other wall of the shower where the shower bench is located?
    Thank you for your help.
  6. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    PriceMan the divertors work in many different ways. Each different but basically you would be using your current fixture to set the temperature and turn the shower on. Then the divertor would dictate what shower fixtures where on. One, Two or Both.
Similar Threads: Handheld Shower
Shower & Bathtub Forum & Blog HIGH flow HANDHELD shower Dec 26, 2016
Shower & Bathtub Forum & Blog Water runs from handheld and wall shower same time Oct 23, 2016
Shower & Bathtub Forum & Blog Remove mount for handheld shower head Jul 31, 2014
Shower & Bathtub Forum & Blog Installing a handheld shower with Ell (Newbie) Jul 31, 2014
Shower & Bathtub Forum & Blog Shower Riser Height for Handheld Shower Jul 8, 2014
