Hand pump? deep well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Loghead, Dec 1, 2009.
  1. Loghead
    Loghead New Member
    Mar 30, 2008
    Can a hand pump be added to a submersiable 102ft dp well if loss of power were to occure for long period of time?. (Grid shutdown.)
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    You can screw a submersible on the bottom of a hand pump. The problem is trying to get the shaft seal at the top of the hand pump to hold as much pressure as the sub can build. Hand pumps were not meant for 40/60 pressure.
  4. Loghead
    Loghead New Member
    Mar 30, 2008
    I was thinking more along the lines of running a 1.25 dia pipe separt but parallel to the submersiable pipe in the 4 in casing.
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    If you can get them to fit side by side it will work well. The only problem there is finding a two hole well seal with the right size holes to get the well head sealed.
  6. Loghead
    Loghead New Member
    Mar 30, 2008
    Thanks for your reply.
  7. David Alan
    David Alan New Member
    Dec 21, 2009
    East Texas
    Thoughts on hand pump.....
    Loghead,
    Can I ask if you had located a nice quality handpump that will work effectively from your 102 ft depth, and at what price ?
    David Alan :)
Similar Threads: Hand pump
Pumps and Tanks Well Forum & Blog. Water is life. Pitcher pump handle tight Dec 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Hand Pump Well Feb 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Hand pump Nov 24, 2015
Pumps and Tanks Well Forum & Blog. Water is life. fittings for "guzzler" style hand pump Nov 8, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Hand pump for very deep well? Oct 15, 2014
