Hand Driving a Shallow Well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by speedbump, Aug 6, 2008.
Thread Status:
Not open for further replies.
  1. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Hand Driven Wells
    Many questions have been asked on Forums about how to install a 1-1/4” or 2” well. There are many pictures and volumes of answers on the Internet on how to accomplish this task. Some are very informative and some are not. Many I have seen use methods that are contradictory to what I believe and have experienced first hand. Before I go into a detailed description, let me just say that the most important thing to do before buying the first piece of Pipe is to call some of the local Well Drillers in your area. They have been Drilling around your home for years and have all the experience needed to guide you in the decision of whether to give it a try or just forget about it. Not all areas in this Country have accessible shallow water.
    What you are looking for is a sandy soil made up of pure sand and maybe some gravel that is not mixed with clay or any other substance that impede the movement of water. This surface water aquifer is somewhere between 5 and 30 feet below your grass. This is not to say that there is any water in it or that it is there at all. This is where your local Driller comes in. Ask him first!
    What’s next?
    Once you have gotten the news from your local Well Driller that there is water in the ground and at what depth it may be found, you are already ahead of the game. Now you’re not driving pipe blindly. You now have some useful information. With this info, you can go buy the 5’ sections of Galvanized Pipe either 1-1/4” or 2”. I recommend 1-1/4" as it goes much easier. This pipe must be threaded on both ends. You will also need to buy some 1-1/4” (or two inch) Drive Couplings. Enough to couple each joint together. One for the Screen ( that will be discussed later), and a couple for the top of the pipe (in case you damage one) while your knocking it into the ground. Some people will tell you to use a Sledge Hammer. I am not one of those people. You will only loosen and or break joints. A Fence Post Driver works fairly well. It is usually a two inch pipe about three feet long and is weighted. It will have two handles to operate it with. Getting a few burly friends and a case of Beer isn’t a bad idea. The joining process means that each joint must have the threads butted together inside the Drive Couplings before attempting to drive the pipe. This will take a couple of 24 inch or larger Pipe Wrenches with cheater pipe on their handles. If you don’t get the pipe threads butted together in the couplings, all you will do is damage the threads and create air leaks. Air is a Jet Pumps worst enemy.
    The Driver.
    The Driver I have pictured below is the best one I have found for this job.
    The head of the driver is 6” pipe capped top and bottom with a 1” solid steel bar running through it. The head has lead melted in it for added weight. The driver weighs around 50 lbs. The one I used as a kid weighed 65 lbs and worked even better. The stem fits nicely into 1-1/4” pipe and is long enough that it can’t come out while you’re using it. I cropped the stem a little to keep the picture smaller.
    The Screen I mentioned earlier should have slots or openings small enough to keep out most sand. Your Driller may be able to help you select the right slot size for your formation. Some of the fine sand will be pumped out until clear, and the larger particles are drawn up against the Screens surface to keep out other finer materials. The type of screen should be carefully thought out. You can run down to the local Hardware store or the Big Box store, but you won’t find a quality Screen there. The openings on these screens are slim to none, and this is what makes a well produce much less water than a screen with more open surface area. The Screen I recommend is a Slotted Screen. It is a series of vertical rods welded to the Point, and the top threaded piece wound with a continuous wire from top to bottom. The distance between the wire winds is how the Screen is identified. A screen with a 10 thousands inch opening between winds is called a ten slot screen. A seven thousands inch opening is called a 7 slot etc. While these Screens won’t take the pounding that the Gauze Screens will, they will offer far more water once in place. They come in Galvanized and Stainless Steel. In my experience, there is no difference.
    After each joint is pounded into place; a Pitcher Pump should be put on the pipe and the Well tested to see if there is any water. Usually; once you get some water with the Pitcher Pump, another joint will be needed to get all the way into the vein. Once a good supply of water has been obtained, you can clear it up with the Pitcher Pump or connect a Centrifugal or Jet Pump to make it clear quicker. You will probably pump sand for a while; this is normal. Once clear, you can assume the Well is done.
    Hooking up the Pump
    Assuming you butted all your joints and did “NOT” use a Sledge Hammer, we can assume that the Casing is air tight and no air leaks should be encountered.
    The top of the Casing can have either an Elbow or a Tee. I recommend the Elbow because it makes one less fitting which could be the source of an air leak. On the horizontal of the Elbow you can add a Close Nipple and a Brass Check Valve. The type of Pipe you use will determine the type of fittings you need between the Check Valve and the Pump. This only takes two more fittings (not counting elbows if they must be used) PVC Pipe would need two male adaptors. Same with Copper. If you use Poly Pipe, you will need two Barb Fittings (sometimes call Male Adaptors) and four good Hose Clamps. If you use Galvanized Pipe, you would of coarse need a Union. If you must add more fittings (I see no reason to do so) remember that you have just introduced that many more air leak possibilities.
    On top of the Pump install a short nipple, with a Tee and a Plug for Priming purposes. Out the side of the Tee is where you would run your pipe to either the tank or what ever your are plumbing to. Hook up the electric, fill the Pump and pipe with water, put the Plug back in loosely to let out air as the Pump catches it's prime. Once water starts squirting out of the Plug under pressure, the Pump is Primed and you can tighten the Plug. That’s it.
    I know there are other methods of putting in Shallow Wells, the Driven Well is only one method. It is the one I used the most and had the best luck with.
    Good Luck...
  2. JayNWA
    JayNWA New Member
    Aug 11, 2008
    You can use a shop Vac (wet/dry type) to dig the hole down to the water level. Use duct tape to secure the flexible vac hose to a section of PVC pipe. I used a hack saw to cut "teeth" into the bottom end of the PVC. Turn on the vac and gently pound the PVC pipe into the ground to loosen up the soil at the bottom of the hole and the vac will suck the dirt right up and out. If you hit rock or clay or other hard stuff try digging another hole.
    When you hit the water table the vac will not be able to dig deeper. That is when you put your metal well pipe and point in and pound it in as described above.
    This can save you a lot of work and you won't have to drive pipe into any dry holes.
    I used this method to drill my well. There was a water table pond about two hundred feet from my house so I know that there was water there. I started vaccuuming holes at my house and kept hitting clay until I was about half way to the pond where I was able to vaccuum down through sand all the way to the water table. Then I pounded the point down another 8'.
    LibertyDiY likes this.
  4. WV Hillbilly
    WV Hillbilly New Member
    Aug 1, 2008
    If you taped the vac hose to the top of the pvc , how did you pound on the pipe . Did you install a tee or something to hook the vac hose to ?
Similar Threads: Hand Driving
Pumps and Tanks Well Forum & Blog. Water is life. Hand dug water well May 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Hand Pump Well Feb 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Hand pump Nov 24, 2015
Pumps and Tanks Well Forum & Blog. Water is life. fittings for "guzzler" style hand pump Nov 8, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Hand pump for very deep well? Oct 15, 2014
Thread Status:
