Hammerin' Away...
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by Hikermann, May 21, 2013.
  1. Hikermann
    Hikermann New Member
    WA
    For some reason the cold water line-in to the washing machine has decided to get noisy; a couple of days ago it was just a bang-thump every couple of minutes when the washer was running, now it's moved to chattering non-stop (guess it's got the chills...); did the water-main-shutoff-open-everything-open-water-main business a couple of times - no solution; added a hammer arrest device at the washer intake; still chatters. Curious is that no cold water comes into the washer drum; I turn it "off" and then "on" again, which causes a minute bit of water to come in and then the "chunk" and it shuts off; hot water works fine.
    Is this an intake valve or some such issue within the machine itself?
    Many thanks for any help.
  2. LLigetfa
    3,826
    NW Ontario, Canada
    FloodSafe hoses?
  3. Hikermann
    WA
    No. Regular woven (stainless steel?) type.
  4. cacher_chick
    3,236
    Have you tried disconnecting the hose and running water into a bucket? There are inlet screens on the washing machine solenoid valve that can become plugged with debris. Take the hose off & look into the inlet.
Similar Threads: Hammerin' Away
Plumbing Forum, Professional & DIY Advice, Tips & What cause this? sewer roof cap eaten away May 5, 2014
Plumbing Forum, Professional & DIY Advice, Tips & True or False? If sweated joints don't leak right away, they won't ever leak. Mar 19, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Getting a new fridge with a larger width - water supply 7 Ft away Oct 1, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Water Hammer wont go away Jun 15, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Replacing in-Ground Basement Floor Drain - Rotted Away May 20, 2012
