Nathan Payne
I replaced a 110V, 35W GE halogen track light bulb since the existing one burned out (or so I thought). Replacing with a new bulb did not fix the problem though. I tried three separate new bulbs and none of them worked. I used a volt meter to check the socket, and there is current flowing. I'm at a loss at this point as to what the problem is. Another point is that I took one of the other track light bulbs that was working out to try it in the socket that isn't working, and now that socket doesn't work with any bulb either, including the bulb that I just took out of it that was working before I took it out. Hopefully this makes sense.
