Runs with Bison
Newer home, installed new toilets to replace builder grade crap. 6th Toto toilet I've put in (one was a repeat for a warped tank that I had to return through supply house), one more to go tomorrow (7th) since it was a late order. Toto should give me a percentage on every move I do...they could classify it as missionary work.
Anyway, had a slow leak this time. In the past I've followed Terry's advice of sanding the bolt holes a little before install. But this time because of the move I couldn't find my emory cloth quickly/easily...and the tank was a little rougher than normal, probably the roughest inside a Toto that I've seen. I wiped it but didn't sand and put it in anyway, all seemed good for the first hour. Noticed a few days later on a recheck that I had some very slow drips. Couldn't seal the leak and it appeared to be a tank bolt on one side. It might have been tank to bowl gasket but didn't look like it (while the bolt on one side had a film on inner tank surface when removed that suggested a leak.) Had good 3-point contact and didn't overtighten either.
So tonight I pulled the tank, removed both sets of bolts, reversed rubber washers and swapped them to the other side. Sanded the holes inside the tank. Reinstalled and all seems tight.
