H7ICAT Halo recessed lights cutting out (overlamp safety feature)
Discussion in 'Electrical Forum discussion & Blog' started by Erico, Feb 5, 2011.
  1. Erico
    Erico Member
    Nov 17, 2007
    Chicago, IL
    M
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    It is because you are using A-lamps, not reflector lamps. A-lamps give out a tremendous amount of heat all around. Reflector lamps concentrate it downward.
    Also, the trim has a lot to do with it. The actual lamp size and selection is based on the trim, not the can.
    Also, if you do not even have the trims in yet this will affect the thermal sensor.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    The type trim will play a role in the fixture. Some trims reduce the wattage to as low as 30 watts
    Go Petey Go
    You posted while I was typing
  5. Erico
    Erico Member
    Nov 17, 2007
    Chicago, IL
    Ahhhhh ha! Thanks.
    So much for the "temp" lights.
    Five bucks shot in the a$$. Not the first. Won't be the last.
  6. jimbo
    jimbo Plumber
    San Diego, CA
    The lights are cutting out so the house does not catch on fire. The IC means rated for insulation contact, and with that rating , they have a thermal cut-out. If you change to a reflector bulb, you will do better.
  7. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Use 23-26 watt CFLs for temp light. Over 100 watts equivalent.
Similar Threads: H7ICAT Halo
Electrical Forum discussion & Blog Halogen lamps inquiry Apr 21, 2016
Electrical Forum discussion & Blog Halogen flood light issues Mar 19, 2016
Electrical Forum discussion & Blog Halogen to LED.. Halogen started smoking Mar 22, 2014
Electrical Forum discussion & Blog Halogen bulb heat... Nov 24, 2013
Electrical Forum discussion & Blog J-type halogen light fixtures Oct 24, 2009
