Gutted living room - Electrical/Insulation question
Discussion in 'Remodel Forum & Blog' started by Rad777, Jan 29, 2009.
  1. Rad777
    Rad777 New Member
    Nov 6, 2008
    Home is built in 1888 in NE Wisconsin. Gutted out the living room due to 2nd story bathroom leak prior to buying it. The room is around 24x35 with a 9ft ceiling. Once the wire/plaster combo was removed, I lost 1.5" of wall thickness which will have to be furred out to meet finished flooring. The siding has 1.5" foam board behind it. My questions are these:
    1. Can I get away with R19? All the framing is 2x4... If I fur out the studs 2 inches could I use R19(6")? instead of R13(3.5")
    2. If I do fur out and use R19, could I simply run the electrical between the strips of furring (in front of insulation)?
    Thank You
  2. hj
    questions
    1. Why wouldn't you use the thicker insulation?
    2. As long as you use nail protective plates over the wiring there is no problem. It would probably violate the electrician's first rule, "NEVER put a wire where it will be out of the way". Electricians ALWAYS put their wires where they cause the most problems for all the other trades.
  4. GabeS
    GabeS Remodel Contractor
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    It's okay to compress the insulation a bit. If you look up compressed insulation charts you would see R-values for fiberglass batt insulation depending on how compressed they were.
    Compressed r-19 in a 2x4 wall has higher r-value than r-13 in a 2x4 wall. Don't forget vapor barrier.
  5. RRW
    RRW New Member
    Jul 15, 2005
    Illinois
    Furring out the walls will certainly allow you to increase the insulation but the problem can also be solved by just running a matching board around the base to take up the space. It would look just fine.
  6. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    24X35? My house could fit inside that room! :eek:
  7. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Actually according to a chart I saved R-19 in a 2x4 wall is R13
    I would furr out the walls & go with more insulation
    Or you could go with R15 in a 2x4 wall
    Heating & cooling costs long term do not go down
    [​IMG]
  8. cc777z
    cc777z New Member
    Jan 31, 2009
    Insulation
    Have you considered blown in foam insulation? It is blown in wet with a special sprayer and drys hard. It also seals every little crack and does not need a vapor barrior. It has a R7 per inch thickness. So a 4 inch depth would be an R28. You don't have to put that much in if you don't want to. 2 inches would be an R14.
    It is more expensive than fiberglass bats. But by sealing all the little air leaks the benefit is even greater than the R rating. It also strengthens the walls.
    It's considered 99% water resistant and approved for sealing the inside basement walls against moisture.
    For more information you can do a google search on spray foam insulation.
    There should be several contractors in our area who provide this service.
    Also do you know what type 1 1/2 foam insulation is already in place? If it is the Pink styrofoam you could already have as much as an R5 to R7 in place.
  9. Rad777
    Rad777 New Member
    Nov 6, 2008
    Thank you all
    Would faced suffice?
    Thank you ScubaDave for the chart... Question however, if anyone knows... Why is R19 thicker than R21? I think I will furr out an an inch and go with R21.
    Also included a photo of one corner, just because
    Yep just double checked, it is that pink stuff about ~1.4" thick
    Thanks
  10. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    I'm not sure on the thickness question
    I just had to go check a roll of R19 - yup 6.25"
    That ticks me off a little that its only R18 compressed into a 2x6 wall
    But R19 is at the big box store & R21 isn't
    And the place nearby that carries R21 charges a LOT more
    I do know the R30c & R38C are for Cathedral ceilings - more dense
  11. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    The R-21 is probably high-density fiberglass (basically, pre-compressed), that's why it's thinner & more expensive.
  12. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    Make sure you inpect all of you studs and joists while you have the walls open. Take a flat head screwdriver and poke all wood every foot of so on the sides and face. Check for termite damage. Look for rot and mold. Sister up where needed. I noticed some of the studs were already repaired.
    What size are you ceiling joists, span, spacing? What's above?
  13. Rad777
    Rad777 New Member
    Nov 6, 2008
    I will measure and take a photo tomorrow and post it. Thanks for the replies everyone!
Similar Threads: Gutted living
Remodel Forum & Blog Opening a Kitchen and Living room wall Mar 22, 2009
