Jeff_Bathroom
Hi,
The dual kitchen sink has issues draining. The left side (disploser side with dishwasher that empties into the disposer), gurgles as it drains. The right side doesn't gurgle, but it is not as fast draining as it should be. These are on an AAV. I replaced the Oatey AAV 6 with a
Studor Redi Vent 16. I have only had the new AAV on there for about a day. It "seems" to have helped
but it might just be wishful thinking and I might be off base entirely. Usually we also get water coming on the right side sink when the dishwasher is running. And if we have a fair amount of water in the disposer sink, turning it on can throw a spout of water up several feet into the air on the right side sink. Now the odd thing is that if I remove the AAV entirely, both sinks drain great, no gurgling and everything is faster. I'm concerned that the gurgling might be air coming through the traps, sucking
the trap or traps dry allowing septic gases in the house. Although I do not smell any odor even with the AAV removed. That could be however because we have a dual septic system. I suspect the kitchen
is hooked to the one meant for washing water and not the bath output. But, I'm just guessing.
One other thing, I took apart both traps and took about a 2 foot long plastic snake as far as I could
reach and I pulled out nothing significant. There was a little bit of gunk in the traps but not enough
to cause any problems. I cleaned the with bleach and put back together. I've uploaded two photos. I can tell you that the dishwasher empties into the disposer and that the two sink traps are at the same horizontal level and connected to the single vertical vent. The Studor is about two feet above the weirs.
Suggestions?
Suggestions?
