GU10 type bulb dimmer
Discussion in 'Electrical Forum discussion & Blog' started by ddagsyn, Sep 27, 2007.
  1. ddagsyn
    ddagsyn New Member
    Oct 17, 2005
    Can the GU10 type light bulb be used with a dimmer
    Thanks
  2. jimbo
    jimbo Plumber
  4. frenchelectrican
    frenchelectrican Electrician
    Jun 16, 2007
    Master Electrician
    NE Wis / Paris France { In France now }
    The other thing about the GU-10 bulb type that come in line voltage and low voltage but here a catch i am sure most will know this but i will remind again with low votlage system make sure you have the right low voltage dimmer they come in magantic and electronic verison.
    just a head up with this.
    Merci, Marc
  5. ddagsyn
    ddagsyn New Member
    Oct 17, 2005
    thank you guys. One more question if the light I need to dim is on a 3 way switch which end can I connect a dimmer to?
    Thanks
  6. hj
    dimmer
    Either end will dim the bulb, put it where it will be most convenient to use it.
  7. Spaceman Spiff
    Spaceman Spiff Architect
    Architect
    Salt Lake City, Utah
    They do make three-way dimmers.
    And, given the right budget and equipment, almost any lamp can be dimmed. This includes arc lamps and flourescent lamps. Flourescent lamp dimmers can now get down to 10%. It's pretty cool to see a 4' tube just barely glowing...
  8. jimbo
    jimbo Plumber
    In a 3-way, be sure to get a dimmer designed as a 3 way. Otherwise, one the other switch wil just give you on/off/.
Similar Threads: GU10 type
Electrical Forum discussion & Blog Correct type of wire to connect to A/C outside unit. Mar 2, 2014
Electrical Forum discussion & Blog J-type halogen light fixtures Oct 24, 2009
Electrical Forum discussion & Blog Transitioning Conduit material types Aug 10, 2008
