Chuck B
sea-bee
I had a new water well drilled for a northern Michigan cottage and used the Grundfos variable speed controller and well pump. The warranty was for two years. Now after four years it failed and I'm facing a $2000 pump replacement. There is 240 V reading at the well head so the pump is getting a call to operate from the controller and current is good. The variable speed controller called out a "no contact with pump" trouble code. We also circumvented the controller and directly connected the powerline from the shut off box to the Well lead and got 240 V but no pump operation. The installer said the copper wires that connect at the wellhead were a little blackened and thought it may have been a lightning strike but I think he's just dodging the problem. My immediate neighbors on the lake had reported no lightning strikes or problems. I would think if it was lightning which I doubt the Romex would be melted and the well cover might also be damaged. The pump operated fine the other morning on a sunny day before it failed. Seems very premature for a $2000 pump and or a $1500 controller to fail in just four years. Any experience with these items? Wondering if there might be some benefit to contacting the manufacturer but it's two years out of warranty. I'm wondering what really caused the problem. Thank you guys
