JKTrevecca
I was hiding some Christmas presents in my crawl-space and noticed my pump is leaking substantially. I bought my home 2 years ago with the pump already installed. In the last 24 hours I've learned a lot about something I never thought of before now. Oh the things I take for granted. I removed the pump and bypassed it last night. The shower this morning left much to be desired.
I have 30-32 psi static pressure without the pump. I can fill a 5 gallon bucket in 1:13 from the lowest faucet in my house which in in my garage in a utility basin. It takes exactly 1:00 to fill the same bucket with the hot and cold valves both wide open. My inlet supply line is 3/4 inch but I live on a hill and my water meter/tap is on the lowest corner of my property quite a good distance from the house. I live on a 1.3 acre lot and the water meter/tap is about as far away from the house as it could be given the shape of my lot.
The pump shaft seal or seals on the Grundfos is the source of the leak. I'm inclined to pay $70.00 for the seal kit and rebuild it but in reading about this pump, I'm finding out it isn't expected to last more than 2-3 years and has a poor reputation. One person I spoke to today suggested I buy an Amtrol Pump/Tank combo system to replace the Grundfos with. He has no skin in the game so has no reason to suggest the Amtrol for his own gain.
Thoughts? Any votes for rebuilding it or is there a clear consensus that it's a paper weight and rebuilding the seals would be futile? If I should replace it, what do you suggest as it's replacement? My understanding is that combining a pump with a tank will result in much longer pump life.
I'm all ears and appreciate any advice you're willing to share.
-- Jason
-- Jason
