Tinka
4 years ago, we opted to 'upgrade' to the constant pressure system. I've just spent some time here reading about them, and am now underwhelmed. Thus far, we've had to replace the pump at 2 years and the controller box at 3 years.
The pressure is awesome, but it never did set well with me that there's no pressure tank and every open of the tap caused the pump to run.
We have been talking with several irrigation system people and our neighbor and friend, the well driller. (not the same one who did our system) Both parties say this system is more than ample to run our irrigation set up, which encompasses about 1/2 acre which will be primarily Rainbirds. There will be several lines of bubblers as well.
We're toying with the idea of dropping a shallow irrigation well with a Flotec sprinkler pump, but if the current house well wouldn't be taxed significantly and supply ample water, we'd simply use the house well. We have about 10 gpm flow off the current setting at 70 psi.
My first dillema was irrigation well vs. house well thinking the Grundfos should do it. Now, I'm realizing that the Grundfos will probably go out in the next few years with or without the watering system. We'll then be out the cost of replacing it, as well as having spent probably $1200 or so to drop an irrigation well.
In my position, what would you suggest? Irrigation well now, and replace the Grundfos with a standard pressure tank and CSV set up when it goes? Would you simply install the irrigation system on the current house well and then replace the Grundfos when it dies, which would probably be sooner as a result of the additional demand?
Thanks so much in advance.
