Grout in shower drain (ABS)
Discussion in 'Drain Cleaning' started by feather, Jan 10, 2011.
  1. feather
    feather New Member
    Jan 10, 2011
    Calgary, AB
    Does anyone know of a safe solution/way to remove grout from ABS pipe?
    The tiler washed grout down a shower drain and now we have a major blockage. So far the only solution appears to be to cut out the affected section of pipe. Not my first choice as it means breaking up the tile floor, part way up the walls and having to retile the whole thing!
    Thanks
  2. Terry
    Aug 17, 2004
    I don't know of anything that removes tile grout that doesn't hurt the pipes too. I have no idea why tile setters dump bits of tile, grout and mortar down plumbing drains. That is totally unacceptable building practice, and the tile setter will need to fix this. You had a perfectly working plumbing system, until the tile setter got lazy and decided to cement the drain shut.
    All he had to do, was walk outside, and clean his tools there.
    I had one job where the tile setter had dumped broken tiles down the toilet drain. I wondered if that was sabotage to the homeowner or just old fashioned ignorance.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You use grout on tile because it is basically unaffected by water, so once it sets, water isn't going to remove it. Go after the tile setter, make him pay for the job. As Terry says, this is unacceptable building practice and a professional tile setter knows better. Or if he doesn't know better now, he will after he or his company pays the plumbing bill!
  5. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Tile Guy dumped grout down drain.
    Like the boys said. Not Good.
    It takes little effort to plug the drain and keep the grout out of your homes system. Dumping grout down the drain and leaving it is horrible and shows no respect for a clients home.
    If a small amount where to drop in and the grout was still wet a long washout with cold or hot water would convert the grout to sand and wash away the portland cement. Removing sand from a PTrap is hard to do and replacing the PTrap is the best approach.
    As sad as it seems this is a common practice and one that can be avoided if the test plug is kept in until the tile job is finished.
    JW
  6. feather
    feather New Member
    Jan 10, 2011
    Calgary, AB
    Thanks guys. There was a plug - but apparently it was easily removed. I guess we're demo-ing the shower!
  7. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    I just ran a electric snake with a 3/8" cable it breaks it out just fine!
  8. hj
    I used muriatic acid to open a drain like that. You have to "suck it out" and put in fresh acid as it gets "exhausted". I had one 3" sewer line through a house that was completely filled with grout for about 20'. That had to be cut out and replaced.
  9. Hairyhosebib
    Hairyhosebib New Member
    Jun 23, 2010
    Arizona
    I actually agree with Yoda. LOL TILE GUYS DON"T GIVE A CRAP UNTIL IT HAPPENS IN THEIR HOUSE!!It would be great if a short masonry bit attachment could be put on the end of a sewer machine cable and it would just drill a hole through it.
  10. hj
    If it would drill through grout, it would have absolutely no problem drilling through ABS or PVC plastic.
  11. Hairyhosebib
    Jun 23, 2010
    Arizona
    You certainly do have a point there. I'm used to working with cast iron.
  12. ResPlumber
    ResPlumber Plumber
    Mar 15, 2011
    Michigan
    I have had success only one time getting grout of a shower drain. I was able to chip it out using a long screwdriver, shop vac with the little hose and a snake. I would chip down as far as I could with the screwdriver then suck out the pieces with the shop vac to get where I could not with the screwdriver I used the snake to bang and loosen up the grout then suck it out it took a while but I was lucky and it ended up working.
  13. hj
    Usually it flows around the bottom of the trap and fills the entire "U" bend, then you cannot get to the section between the bottom of the "U" and the outlet.
Similar Threads: Grout shower
Drain Cleaning Upstairs toilet & shower drain into kitchen sink. Basement sink drains ok to sewer Mar 28, 2016
Drain Cleaning Constant shower drain backup Jan 28, 2015
Drain Cleaning Possible broken drain pipe, shower, toilet, sink clogged. May 31, 2014
Drain Cleaning Slow shower drain Jul 1, 2013
Drain Cleaning Could first use of new basement shower cause backup in floor drain? Weird situation Mar 27, 2012
