Grounding or Bonding Jetted Bathtub
Discussion in 'Electrical Forum discussion & Blog' started by seegee, May 3, 2012.
  1. seegee
    seegee New Member
    May 3, 2012
    CA
    Hi All,
    I'm sorry, this may have been asked before, but I want to make double/triple sure I have this right.
    I have a jetted Proflo tub that was installed in my new home. There is only 1 Romex cable to supply power and ground. There is no heater on the unit, and I am using aquapex for the water supply. There is what looks like a grounding/bonding bolt on the motor, but if I'm not using copper pipes, and there is no heater unit, is it necessary to connect anything to that bolt?
    Just want to be safe and sure. Thanks in advance.
  2. jadnashua
    What does the installation manual say? My guess is that it does need to be grounded, if nothing else, but that is a guess.
  4. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    i would bet that the motor would have to be grounded, as well as hooked up to a GFCI outlet as well.
  5. seegee
    seegee New Member
    May 3, 2012
    CA
    It just says the following:
    In one area:
    Electrical Requirements
    1. ALL CONNECTIONS MUST BE GFCI (Ground Fault Circuit Interrupted) PROTECTED
    2. Whirlpool units require dedicated 20 amp, 115 volt service.
    3. A receptacle with a 20 amp configuration must be provided.
    4. See local codes for proper wire size, if not specified use #12 Copper only wire.
    In another area:
    DANGER: RISK OF ELECTRICAL SHOCK! Connect only to a separate circuit protected by a ground fault circuit
    interrupter (GFCI).
    • The unit must be connected to a circuit interrupter (GFCI). Such a circuit is provided by the installer and should be
    tested on a routine basis. To test the GFCI push the test button. The GFCI should interrupt power. Push the RESET
    button. Power should be restored. If the GFCI fails to operate in this manner, there is a ground current flowing, indicating
    the possibility of an electrical shock. Do not use this unit. Disconnect the unit and have the problem corrected
    by a qualified service representative before using.
    Another area:
    Electrical connection is simply made by plugging pump cord (shipped with
    cord and plug) into specified dedicated 120V/20A GFCI outlet.
    IT IS CONNECTED TO A GFCI CIRCUIT.
  6. jadnashua
    Well, electrically speaking, a gfci doesn't even require a ground, although it does give a safety path to trip the CB if there's some types of shorts.
  7. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    The lug on the motor has nothing to do with grounding. The grounding is accomplished by the bare copper wire in the cable supplying the receptacle.
    The lug on the motor is for bonding any and all metal parts in the area of the tub together. If there are no metal water pipes and no other metal that can be touched while in the tub then it gets hooked to nothing
  8. Chris DeLong
    Chris DeLong New Member
    May 5, 2012
    New Jersey
    The bonding lug on the motor is for bonding any metal parts in contact with the circulating water only, In my experience, I have never seen a tub plumbed with anything but plastic... so IMO you don't have to bond anything.
  9. seegee
    seegee New Member
    May 3, 2012
    CA
    Yes, there are no metal water pipes, but the plastic water pipes of course connect to the tub spout and hot/cold control knobs, which are metal. Those don't need bonding, right?
  10. seegee
    seegee New Member
    May 3, 2012
    CA
    bump... just wanted to know this last piece...
  11. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    No bonding required
Similar Threads: Grounding Bonding
Electrical Forum discussion & Blog Grounding, bonding, old swimming pool Feb 23, 2014
Electrical Forum discussion & Blog 2 grounding/bonding questions Feb 14, 2014
Electrical Forum discussion & Blog Grounding electrode/bonding question Oct 10, 2012
Electrical Forum discussion & Blog Grounding Whirlpool Tub Motor and Heater - Bonding Panel to Electric Water Heater Feb 5, 2012
Electrical Forum discussion & Blog bonding/grounding copper pipes Nov 18, 2010
