Grounding gas line to panel...
Discussion in 'Electrical Forum discussion & Blog' started by deerme, Apr 16, 2009.
  1. deerme
    deerme New Member
    Apr 16, 2009
    I just moved into a 2 yr old house that has a gas fireplace that's never been used. The gas company won't put in a tank until the gas line is grounded to the electrical box.
    I understand I need to get 6 gauge copper wire and attached it to where the gas line connects to the fireplace using a bonding clamp, then run the wire to the panel and attach it to the ground bar. I have some questions about this....
    Does the ground wire need to be encased in anything? I'll be putting it through one wall, too.
    What do I use to secure the wire along the beam in the basement?
    Is there a special way to connect the wire to the ground bar? Do I need to shut off the main breaker prior to connecting to the ground bar? I dont' want to get zapped!
  2. Ian Gills
    Jul 24, 2007
    USA
    If you need to ask this question then you should not be doing this job. Call an electrician or read up on home electrics.
  4. deerme
    deerme New Member
    Apr 16, 2009
    Well that's kind of why I'm here :)
    Thanks anyway...
  5. Ian Gills
    Jul 24, 2007
    USA
    Sorry, and I do like DIY so I sympathize with why you are asking. But going into the panel was one of the last things I learnt to do with the electrical tinkering in my house. You really are playing with death in there even with the breaker off (parts of the panel will still be live). That's why the gas company wants somebody qualified to do it.
    If you are not absolutely proficient in fitting a new receptacle, rewiring part of a circuit, installing a new light fixture or a switch then you should not be jumping straight into electrical panel work. And if you need to ask what you secure wire with, then you clearly are not familiar with these tasks.
    The only thing worse would be having a plumber try to do it...:)
  6. hj
    quote; The only thing worse would be having a plumber try to do it...
    Why? I have wired complete houses and commercial suites.
  7. Ian Gills
    Jul 24, 2007
    USA
    Sorry HJ, I did not realise you were a licensed electrician as well as a plumber. :)
    [​IMG]
  8. 3m
    3m New Member
    Mar 3, 2009
    NY
    I hold a Plumbing contractor license from the state of Indiana and a Master Electrician license from the city of Evansville Indiana and NO I wasnt grand fathered in so I see no problem with a plumber doing it if HE OR HER knows what they are doing
  9. Ian Gills
    Jul 24, 2007
    USA
    And if that be the case then neither do I Sir.:)
    [​IMG]
  10. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    First, it's a BOND wire, not a ground wire.
    No
    Staples....straps....anything.
    Screwdriver???
    YES!!
  11. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    The requirement to bond the gas line is not a NEC requirement but a manufacturer requirement and then only if there is some sort of flexible gas line being used.
    If there is a flexible gas line somewhere in the gas piping system then the bonding jumper can land anywhere out lined below;
    …shall be bonded to the service equipment enclosure, the grounded conductor at the service, the grounding electrode conductor where of sufficient size, or the one or more grounding electrodes used.
    There is no need to open the panel at all.
    Install one of these sized for two #6 conductors on the #6 running to the ground rod and the other end to the gas pipe with water pipe clamp. The water pipe clamp must be on solid pipe.
    clcik on the blue underlined words
  12. killavolt
    killavolt In the Trades
    Apr 9, 2009
    Licenced electrician
    Southington CT
    Jwelectric, are you getting any flack from electrical inspectors on the use of split bolt connectors? Here in CT, I've run into quite a few that won't allow their use. They claim the split bolts could fail and make us use bypass connectors.
  13. deerme
    deerme New Member
    Apr 16, 2009
    This is VERY helpful information. Thanks!!!
    The gas pipe is "Trac Pipe" and you're right, it is the manufacturer that requires the pipe be bonded.
    I could call a different gas company and they'd probably come set a tank w/out making me bond the line, but if it's a matter of safety I'd better get it done.
    Here's what the manufacturer says. Evidently a lightning strike could create pinholes in the line causing a SLOW gas leak. Doesn't sound good!
    Thanks again for your help!
  14. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    I don’t have problems from electrical inspectors on anything I do simply due to the fact I am very proficient on the NEC.
    Unless the electrical inspector can show me in writing where I am wrong I just send him/her on down the road kicking cans and counting poles.
    When a split bolt is installed properly they will not come lose without someone or something helping it to happen. In my years of doing electrical work I do not know of the first one coming lose.
  15. Alectrician
    Jun 15, 2007
    Assuming of course that he has access to the GEC.
    His house is two years old and would probably have a ufer and it will likely be concealed.
Similar Threads: Grounding line
Electrical Forum discussion & Blog Grounding after changing to plastic service line Feb 27, 2012
Electrical Forum discussion & Blog Creating a new earth connection for grounding an outlet Feb 19, 2017
Electrical Forum discussion & Blog Proper grounding of 3-wire submersible pump in metal well casing Jan 23, 2017
Electrical Forum discussion & Blog Wiring New Electric Range - Grounding Oct 7, 2016
Electrical Forum discussion & Blog Grounding Rod Requirements - Washington State? Aug 23, 2016
