Grounding, bonding, potential??
Discussion in 'Electrical Forum discussion & Blog' started by hammerslammer, Aug 20, 2007.
  1. hammerslammer
    hammerslammer New Member
    Dec 10, 2005
    Colorado
    I keep thinking there is a fairly simple explaination or maybe a drawing that can set me straight on grounding, bonding , and potential. I've read quite a bit on the subject and consider myself of reasonable intelligence. Why can't i get this?? Any help would be appreciated.
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Ask a specific question and receive a specific answer.
    Grounding is connecting to earth
    Bonding is joining together
    Potential is capable of
    Just what are you having a problem with?
  4. jimbo
    jimbo Plumber
    San Diego, CA
    A grounded item something which is somehow connected to the earth gorund, electrically.
    A grounding conductor is the wire which connects something to ground. The bare wire in your outlets etc. is a grounding conductor.
    Bonding connects two things together. In you main service panel the neutral bus bar is bonded to the ground bus bar. In your house, the metal water pipes are often bonded to the electrical grounding system.
    EMF ( electromotive force) is also referred to as a difference in potential between two points . Potential means potential energy. It is energy which has the ability to do work if a means is then provided for current to flow between the two points.
  5. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    and bonding equalizes the potential between the things being bonded - so you won't get shocked by touching both at once.
  6. jadnashua
    One thing to confuse things, but interesting, is when working on high voltage things like a regulator, or an rf generating device that is operating at high voltages. They often have the filaments at a potential of say 5-7 volts dc, while the stuff around them is at 5000vdc or higher. If you measured from the filament to ground, you'd get maybe 5005, but if you measured between the two leads, 5 volts. This is where understanding what the reference, or bonded point, can be very interesting and dangerous. Neither side of the filaments in this case are referenced or bonded to ground, but one side of the filaments is bonded to one side of the high voltage supply. They do this so you don't end up with arcing internal to the tube.
Similar Threads: Grounding bonding
Electrical Forum discussion & Blog Grounding, bonding, old swimming pool Feb 23, 2014
Electrical Forum discussion & Blog 2 grounding/bonding questions Feb 14, 2014
Electrical Forum discussion & Blog Grounding electrode/bonding question Oct 10, 2012
Electrical Forum discussion & Blog Grounding or Bonding Jetted Bathtub May 3, 2012
Electrical Forum discussion & Blog Grounding Whirlpool Tub Motor and Heater - Bonding Panel to Electric Water Heater Feb 5, 2012
