Grounding a submersible pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Arky217, Jun 21, 2013.
  1. Arky217
    Arky217 New Member
    Jan 20, 2008
    Arkansas
    Just had a well drilled with a PVC casing; for lightning protection, driller said to tap into the ground wire at the well head and run the tap to a driven ground rod near the well head.
    In other words, the ground wire from the service panel is to go to a driven ground rod located near the well head and then continue on down the well to the pump ground.
    Does this sound right ?
  2. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    We run the ground from the pump to the well cap & casing and then to the controls in the house. The electrician then grounds it back to the breaker box.
  4. Arky217
    Arky217 New Member
    Jan 20, 2008
    Arkansas
    That makes sense if the casing is metal, but mine is PVC. So, would a ground rod subsitute for the metal casing ?
  5. craigpump
    Apr 12, 2012
    You shouldn't have to do that if the breaker box already has a ground rod.
  6. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    A single ground rod would be a poor substitute to what a metal casing can do in so far as dissipating lightning. It would probably take a dozen ground rods to be the equivalent of what a metal casing can be. Code would require that you use #6 wire to bond between grounds.
    Lightning protection is complex and the amount of protection needed can vary by the situation. I have done work in that field, grounding high tension lattice towers for the POCO. For comprehensive protection, each situation needs to be evaluated and in the end, the cost of the protection needs to be weighed with the cost of replacement.
Similar Threads: Grounding submersible
Pumps and Tanks Well Forum & Blog. Water is life. Submersible Pump Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Have a F&W submersible pump seems to have stopped, replaced QB control box Jan 30, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Am I getting ripped off on a submersible pump? Jan 25, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump problems Jan 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. HELP PLEASE.. New submersible well pump clogging lines with shell fragments Dec 26, 2016
