Grounding a Jacuzzi Bathtub
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by scolby, Feb 12, 2014.
  1. scolby
    scolby New Member
    Feb 12, 2014
    pa
    I have a Jacuzzi bathtub to install and it says it requires:
    separate GFCI, 15 AMP circuit
    AND it says "using a #8 solid copper wire, ground the pump motor to the house electrical panel, or approved local ground. A grounding lug is provided on the motor"
    does this mean that I need to install a ground wire from that grounding lug all the way back to the breaker box panel?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    It is the installer's responsibility to install it in accordance with the manufacturer's instructions, so yes, that is what it means.
  4. scolby
    scolby New Member
    Feb 12, 2014
    pa
    Thank you. Do we just run that wire exposed along side the romex going back to the box?
  5. DoofusOfTheDay
    DoofusOfTheDay Member
    Feb 25, 2005
    Computer Geek with Big Blue
    Atlanta GA metro area
    I just helped remove a jacuzzi bathtub and noticed the grounding wire from the motor to the cold water copper pipe supply for the tub. Would the cold water supply pipe be acceptable as an "approved local ground"? Wondering if the tub I helped remove was installed incorrectly or if cold water supply copper pipes are okay to use for ground.
  6. hj
    quote; if cold water supply copper pipes are okay to use for ground.
    At one time it was legal, but not any more, because there is always the danger that someone will replace a section of it with plastic pipe, or isolate it with "dielectric" connectors.
  7. DoofusOfTheDay
    Feb 25, 2005
    Ah okay, that makes sense. A little bit older home, so maybe legal back then.
  8. jadnashua
    The codes are written for those 'what if' situations, and over time, more of them get discovered and various fixes get applied (the codes are a living thing - they change). Way back when, there was no approved plastic piping, and it was considered a viable grounding point. Today, the pipes can be bonded to ground, but cannot be a viable ground by themselves.
  9. Vegas_sparky
    Vegas_sparky Digital Billy
    Dec 5, 2013
    Electrician
    LV,NV/ Nowhere,UT
    Yes, that is fine.
    Just to add, the #8 bonding wire will not enter the jbox that will hold the tub receptacle. Typically the bare wire will simply come up through the subfloor, or out of the wall near the physical location of the motor.
  10. hj
    quote; Just to add, the #8 bonding wire will not enter the jbox that will hold the tub receptacle.
    IT would not be much good if it did, because there should be a grounding lug on the pump motor for that wire to attach to.
Similar Threads: Grounding Jacuzzi
Plumbing Forum, Professional & DIY Advice Effluent Pump Grounding Nov 18, 2015
Plumbing Forum, Professional & DIY Advice Copper pipe grounding/bonding - how to? Dec 29, 2010
Plumbing Forum, Professional & DIY Advice bonding/grounding and pex Oct 22, 2009
Plumbing Forum, Professional & DIY Advice Removing Jacuzzi Air Control Knobs Jan 30, 2015
Plumbing Forum, Professional & DIY Advice 3 questions regarding installation of a replacement assembly to stop a Jacuzzi leak. Dec 12, 2013
