Grounded Armored Cable?
Discussion in 'Electrical Forum discussion & Blog' started by onestepahead, Jun 8, 2010.
  1. onestepahead
    onestepahead New Member
    Jun 8, 2010
    NJ
    Hello-
    My house is over 70 years old. Wired with armored (BX) cable - cloth wrapped hot & neutral inside. No ground wire.
    I've been gradually replacing ancient receptacles with 3-prong ones. I've been pigtailing the ground screw to the metal outlet boxes. I've been testing each box with with a voltage tester (one of those little ones that's just a small light), and I've since acquired one with a digital readout for the last few. Indeed, I'm seeing the same voltage (~124v) from hot to neutral as hot to ground - indicating (i think) that the boxes, via the armored cable, are grounded.
    However, I've recently read some postings claiming that armored cable doesn't provide true ground - that there is so much conductive material joined by the boxes and all of the cable sheathing that current will flow into it, but that there still may be a more direct path to ground in the event of a short circuit.
    so, is that true?
    I have no way to measure the current, only the voltage. Do I have a grounded system?
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    This is very true.
    The problem is not that of finding a different path, it's one that a fault will follow the spiral of the sheathing and not run along it in a linear path. This creates very high resistance and can cause the sheathing to be a heating element instead of a fault current conductor.
    Modern AC cable (~1960's on) has a thin bonding strip that "joins" all the spiral coils and lats fault current flow directly down the cable.
  4. Ford2001
    Ford2001 New Member
    Sep 11, 2009
    property care taker
    Manchester, Vermont
    Speedy Petey answer was very good. I would just add, If the amored cable is not a good grounding conductor, install GFCI duplex receptacles. This is an opinion on mine. Replacing the old BX cable is better, if you have the funds to do this.??
Similar Threads: Grounded Armored
Electrical Forum discussion & Blog Ungrounded light fixture Jan 17, 2016
Electrical Forum discussion & Blog Garage door grounded? Sep 2, 2015
Electrical Forum discussion & Blog Home PC, ungrounded outlet and CFCI Apr 2, 2015
Electrical Forum discussion & Blog Will GFCIs Make Grounded BX Safe? Dec 21, 2014
Electrical Forum discussion & Blog Dimmable LV track light humming & grounded neutral Mar 7, 2011
