Ground Rod Dryer
Discussion in 'Electrical Forum discussion & Blog' started by vman, May 13, 2009.
  1. vman
    vman New Member
    Jan 6, 2008
    Massachusetts
    I was building out a basement laundry. The electrical main is grounded to a rod in my basement. The rod sticks up about a foot or so. I'm wondering if there is any issue placind a dryer or washer near it?
  2. thassler
    thassler Member
    Dec 5, 2006
    Systems Analyst
    Tennessee
    I'm only a DIYr but I wouldn't think there would be a problem as long as the ground wire back to the panel is somewhat protected from damage. I wouldn't want an out of balance washer walking around on the ground rod or wire.
  4. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    The ground rod is not doing very much so there is no problem in putting things near it. Many times the water pipe entering the house is used for the same purpose so think of it that way.
    The thing I have a problem with is the fact that it is a hazard and code violation that it is a foot out of the ground. It should be flush.
  5. drick
    drick In the Trades
    May 16, 2008
    Or at least cut it off with a sawzall and bang on it for a bit to make it look good:D Um.. not that I or anyone I know has ever done that.
  6. 3m
    3m New Member
    Mar 3, 2009
    NY
    It is code to connect the ground to reed bar installed in the footers, but the wire should be protected from damage, and if its sticking up a foot that sounds dangerous, normally they only leave a few inches sticking up
  7. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Yes, it is code to connect to the rebar in the footer. How to you propose he get to it?
  8. 3m
    3m New Member
    Mar 3, 2009
    NY
    He or She may already be at it, on one of the previous post he recommended that you pound on or cut the rod, I would prefer the rod be cut just in case it is a reed bar that is incased in the footer and pounding on it with a hammer may break it loose and you loose your ground
  9. Speedy Petey
    Jun 16, 2007
    NY State, USA
    OH, you are say this might actually BE the rebar. I see now.
    This is not a bad assumption, especially if the house is newer.
Similar Threads: Ground Dryer
Electrical Forum discussion & Blog Dryer Static - modify dryer grounds....amicrazyorwhat? Nov 29, 2013
Electrical Forum discussion & Blog ROMEX® to dryer outlet - insulated ground? Dec 18, 2009
Electrical Forum discussion & Blog Underground UF Wiring Gauge Selection Feb 22, 2017
Electrical Forum discussion & Blog Creating a new earth connection for grounding an outlet Feb 19, 2017
Electrical Forum discussion & Blog Electrical panel- no ground Feb 1, 2017
